Other Parts Discussed in Thread: BQSTUDIO, EV2400
Hello everyone
I only use BQ76952 to monitor the battery voltage, current and temperature, using the default configuration, when I give the RST _ SHUT pin a high level, the pin measuring TS2 does not output a high level?
According to DATASHEET, TS2 should output a high level in shutdown mode.
There is only one normally open switch connected to the TS2 pin.
THANKS!
Xia Chime
