Other Parts Discussed in Thread: TPS63900
Hi Team,
My customer is experimenting with the TPS631000EVM with an input voltage of 2.6V, output 3.3V and load current of ~20mA (160-Ohm load resistor). When they took a measurement at L1 and L2 it showed two close pulses followed by a delay before repeating 2 pulses again. The PFM/PSM in the datasheet says it operates in "single pulse mode to reduce output ripple." What could be causing this additional pulse?
Thank you,
TR
