LM34936: LM34936- Bias pin is stated as floating in PSpice, can't simulate design.
Part Number: LM34936
Hello.
I copied over a design from WEBENCH into PSpice for TI because my design requires a bit of additional circuitry. When trying to simulate the WEBENCH design in PSpice, I get the error: ERROR(ORPSIM-15142): Node BIAS is floating. BIAS is the pin connecting the Bias pin on the LM34936 to Cbias, so there is no reason it should be floating in my mind.
My ground nets are named 0, so there shouldn't be an issue there. Attached is the schematic in PSpice.
  Pspice schematic.pdf
Is there any way to fix this? Thank you.
