Is there a limit to the charge/discharge rate of the timing capacitor? I have calculated a Ton of 2.66us and a Toff of 7.56us for my application. This gives a timing capacitor value of about 47pF (in application), which results in a Tchg of about 2.6us and a Tdschg of about 400ns resulting in a frequency of about 330kHz. Is this a problem? The switching frequency is 1/(Ton+Toff) = 97.8kHz. I understand that depending on the load, the switch may switch at a higher frequency on occasion and depends on the output capacitor and ripple voltage.
