Hi Experts,
Our customer wants to use only a half part of the LMG1210 as a driver amplifier. Is it possible to connect HS and VSS together to the GND? Thus the customer will only use the upper side as a driver amplifier and HO is the output of the driver. Please see the picture below.
Another inquiry, if the customer only use the lower side, shall he need to connect HS to GND aiming to avoid any influence from the circuits or just leave HS pad floating?
Kind regards,
Marvin
