Other Parts Discussed in Thread: TLV1117, TLV1117LV
Hi Team,
figure1 in the datasheet, what's the unit of horizontal axis?
If it is time, how many seconds is a grid?
Beat Regards,
Tom Liu
Hi Team,
Beat Regards,
Tom Liu
The horizontal axis is time. I am not 100% sure about the units of it but according to the data sheet, the startup time is 100 us and we can see that in figure 1 it takes about 100 usec to startup so I am assuming that each division is 50 usec. I have attached an image of the data sheet. The only difference I see is the Cout but that shouldn't really affect it. Please let me know if you have any other questions.
Thank you,
Josh Nachassi
Hi Josh,
Thank you for your reply.
For TLV1117LV, the Startup time is mentioned on datasheet as 100 µs, but for TLV1117, it is not shown on datasheet.
What's the Startup time of TLV1117, is it same as TLV1117LV?
Tom Liu
Hi Liu,
We don't have that data on the datasheet as you stated. I will have to order the TLV1117 and then test it to give you a proper answer which will take around 2 weeks. The startup times might not be the same. Please let me know if you want me to order the part and test it.
Thank you,
Josh Nachassi
Hi Josh,
If you have calculated the theoretical value of turn on time for TLV1117, please let us know.
If you haven't, can you tell me the approximate value or the measurement value and measurement circuit?
Tom Liu
Hi Liu,
There is no way to calculate the startup time. We can order the part for you and test it.
Thank you,
Josh Nachassi
Hi Josh,
Could you test the turn on time for TLV1117 and share the measurement circuit with us?
Tom Liu
Yes I can order the part and test it. In the meantime, I can help you find an LDO with similar specifications and a startup time you are looking for. Can you give me an idea of what the customer wants?
Thank you,
Josh Nachassi
Hi Josh,
There is no any response from customer so I think just test the turn on time first.
Thank you very much.
Tom Liu
Hi Liu,
I just tested the part and got around a 25 microsecond rise time. Please let me know if you have any other questions.
Thank you,
Josh Nachassi
