Other Parts Discussed in Thread: TPS92515HV, TPS92515
I have a request to dimmer 48V LED board using constant voltage drivers with pwm output (for example meanwell-pwm series that works at 1.47kHz or others slower drivers that are working at 100Hz).
LED driver will be powered on and off continuously...
Few months ago, Yuting Shao suggest me to use TPS92512HV, but also tells me that a new devices will come...
There is a new device suitable for this dimming method?
TPS92515HV should be ok?
Do I have to use any precautions for this type of dimmer? (or I have only to follow datasheet?)
Thank you for your support
