LM1117: Design Clarification
Part Number: LM1117
Hai Sir,
Based on Customer recommendation we are using LM1117T for voltage conversion.
End application- Controlling & Analog outputs driving.
Can you please give me the clarification about my queries posted below...
1) Designing Vin= 5V and Vout= 3.3V, Iout= 300mA (Step down conversion)
 -> As per the Datasheet reference Figure 9-3. Fixed Output Regulator , page no.16. Downloaded the Pspice model from TI, Simulated and Verified the Results as per the design.
-> Here external components used Cin- 10uF, Cout- 10uF . Can we use these capacitor values with Ceramic capacitors with series resistors for ESR.
-> or Can we use Cin-10uF ceramic capacitor and Cout-10uF Tantalum capacitor.
    I would recommend using tantalum caps instead of ceramic caps for all applications as stated in the data sheet.
    I would be consistent with the data sheet and what types of capacitors it specifies.
    Please let me know if you have any further questions.
    Thank you,
    Josh Nachassi
