Hello Forum,
The only mention of BQ24075T in the specs is on page 6 where the difference between BQ24075 and BQ24075T is the method (voltage vs current) of monitoring the battery temperature.
Can it therefore be assumed that the parts are fully interchangeable and the difference is only internal?
Thank you.
Hi Igor,
Yes, the method of TS is the only difference. These are fully pin to pin compatible but it is important to adjust the TS portion of the schematic.
You can find some more inofmration here: [FAQ] BQ24072T: What are the differences between the BQ24072T and the BQ24072? - Power management forum - Power management - TI E2E support forums
Anthony Pham
Hi Anthony,
My original question was, are these parts interchangeable. If BQ24075T requires 2 additional resistors to set a voltage divider for the temperature monitoring to work, than the answer is NO.
Thank you for your prompt reply and support.
