I accidently connected EEPROM I2C line pull-ups to the local 3.3V instead of TPS25750 LDO_3.3V.
Q1: After powering on the USB power (V3.3_LDO_PD), when I turn on the local 3.3V (V3.3_LOCAL), I don't see any EEPROM loading in I2C line.
Could you confirm that this is the expected behavior?
Q2: Is it possible to load the EEPROM by sending commands through the I2C port?
Thanks for your support,
Choon Shin.
