Iam using TPS65135RTER for split supply as limiting voltage for diodes
Kindly review my layout and schematic
Hi Shyam,
Our datasheet recommends that the FB current is at least 10uA, so R54 to recommended to be 124kohm.
BR
Patrick
Hi Shyam,
1. The trace between OUTN and R56 is too wide, you can refer to our datasheet layout guideline.
2. Is the OUTN going through vias to the bottom layer? It's recommended to place OUTN on one layer, I'm afraid the vias might cause some unexpected issues.
BR
Patrick
