Hi Team
Excuse me, the read values of (Offset = 16h) and (Offset = 18h) are cognitively the same, but why the read values are different, what is the reason? THX
Hi Team
Hi, Kygo
Sorry, I cannot understand your questions. You want to know 16h and 18h are different, is it correct?
Hi Zhiqian
Thank you
目前客戶那邊遇到一個問題
(Offset = 16h)與(Offset = 18h)讀出來值,目前讀出來值是不一樣的,認知上應該會相同才對 ,這有可能會是什麼原因? THX
Hi, Kygo
This two register may not be the same, one is the input, another one is output. It is related with the dimming mode you choose.
If you don't use PWM input pin, 0x16 is zero; if you use analog dimming, the 0x18 is zero.
