Other Parts Discussed in Thread: TPS65987
I dump this register TPS65988(DX) in the screenshot.
1. what is the difference variant between DX and DH ? I checked the Datasheet SLVAE21A.pdf in page 4, section 4.2 Flash memory org. mentioned about DH/ DX.
2. I read the offset 0x00 for VID the value is 0x0 is this correct ?
3. I read the offset 0x1 for DID the value is 0x32454341 , is this correct?
4. in offset 0x1A for status, if I plug a device for example usb memory sticks, the bit 0 the plug present value should be 1 (plug present) correct ?
bit 3:1 the Connstate should be any connection state changes.
Sofian
