Other Parts Discussed in Thread: TPS25750, USB-PD-CHG-EVM-01, EV2400, BQ25720, , BQ25792
Hello TI,
I want to configure TPS25750, but it's shows Dashboards, Applications, and Components are distributed with a TSPA license.
Rahul
Hello TI,
Rahul
Hi Rahul,
Please make sure you are using the latest GUI version which can be found on TPS25750 device page:
You can also go to directly by using this link: https://dev.ti.com/gallery/info/USBPD/TPS25750_Application_Customization_Tool
Very Respectfully,
Brandon Beader
Hello Brandon,
Can I configure TPS25750 USB-PD-CHG-EVM-01 by using EV2400..?
I have TPS25750EVM but it has BQ25720 battery charger IC or there is any way to configure USB-PD-CHG-EVM-01 by using TPS25750EVM..?
Hi Rahul,
Yes, you can use the TPS25750 GUI to configure USB-PD-CHG-EVM-01. There is a questionaire that you will need to fill out for pairing TPS25750 with BQ device.
Very Respectfully,
Brandon Beader
Hi Brandon,
You have any reference or document for that, which help us to speed-up and close issue quickly.
Hi Rahul,
Please refer to these tutorials below for flashing the TPS25750EVM and the USB-PD-CHG-EVM-01:
TPS25750EVM: https://www.youtube.com/watch?v=_y61fyUjo9E
USB-PD-CHG-EVM-01: https://www.youtube.com/watch?v=V_5rofNa_OA
You can also refer to this FAQ regarding recommended parts for flashing the CHG EVM: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1021134/faq-how-do-i-configure-the-tps25750-and-flash-the-eeprom-with-the-output-binary-for-the-board-usb-pd-chg-evm-01
The EV2400 is only meant to be used for getting a register dump of the BQ25792. To configure the TPS25750 on the CHG EVM, you would need to follow the tutorial linked above.
Thanks and Regards,
Raymond Lin
