Other Parts Discussed in Thread: TPS6594EVM
This is an additional question to a previous question.
As a result of investigating the cause, it was found that a voltage was applied to PMIC(VOUT_LDO1) from the outside.
I'm guessing that this is the reason why the write could not be performed normally.
Is it normal for the PMIC to not be able to write due to the reverse voltage being applied to the PMIC output?
best regards
