Could you please help us , how to work TLC6C5748EVM by LAUNCHXL-F280039C ?
It would be helpful if you could tell me how to set it up in detail.
Current setup is pdf CCS v 10.4.0
Using project file TLC6C5748_Q1_Sample_Code supplied by TI support member.
Hi Takahito,
From the title of this thread, I think you are using MSP-EXP432P4111 instead of F280039C.
Could you pls refer to this thread first?https://e2e.ti.com/support/power-management-group/power-management---internal/f/power-management---internal-forum/1194262/tlc6c5748-q1-how-to-modify-the-sample-code?tisearch=e2e-sitesearch&keymatch=TLC6C5748-Q1%2520sample%2520code#
BR, Gracie
Hi Gracie-san
Sorry, I can't find this link...
Currently , I use MSP-EXP432P4111.
I want to change to F280039C.
/Hi Takahito-san,
Since we only have sample code for MSP-EXP432P4111, could u pls tell me which part you want to modify?
From this user guide, at least the basic number, control data and GS data could be changed.
BR, Gracie
Hi Gracie-san,
Sorry, The sample code meets what we want to control. (I need to change basic number, control data and GS data only)
This is because the MSP-EXP432P4111 may be in a bad state and I want to run F280039C with a backup board.
Another question ,
An error has occurred in the lighting display of the EVA kit.
Could you please confirm pdf file p2? Any advice would be appreciated.
1201395_Question-MSP-EXP432P4111.pdf1201395_Question-MSP-EXP432P4111.pdf
Hi Takahito-san,
Changing to another MCU is not simply switching to another target config. It needs quite a few changes in the setting and currently I don't have the resource to do the code transfer.
In your actual system, do you need a MCU like F280039C or you have a TCON on the board and only need this MCU to see the simple function test of TLC6C5748-Q1? If your actual system doesn't have F280039C, I can send you a new MSP-EXP432P4111 launchpad. If you indeed want F280039C to do the design, let's work out it together.
As for the problem you met with current system, SIN and SOUT is really abnormal. I can send you the code again. If at this time, SIN still has no output, I doubt maybe the MCU is broken.
https://tidrive.ext.ti.com/u/7JfrP0KX6xz-l-sw/40afcb56-a701-4e24-98a4-df9c4029cad4?l
access code: viK8j[8P
BR, Gracie
Hi Gracie-san,
Thank you for reply.
I understand not easy to transfer MSP to F280039C.
Same situation when running with new program.
I want to know "SIN and SOUT is really abnormal." and "MCU anomalies are suspected"
Could you please send new MSP-EXP432P4111?
I couldn't buy MSP-EXP432P4111 and asked this thread.
Hi Takahito-san,
No problem. Pls see private message I sent to you.
BR, Gracie
