Hi Team,
My customer and I had a question with the description in the DS. It said that the TPS63080x support "True shutdown function with load disconnect".
The customer connects a 1 cell battery (3V~4.2V) at TPS63806 output. We would like to know that when there is no voltage on input pin and EN pin is low (Device disable). Will there be any leakage from the load (battery)? Thank you.
Mike
