Other Parts Discussed in Thread: LM5012, TPS61046
Hi Dears,
Our customers have used many TI power chips, such as BQ25302/ LM5012/TLV75518 / TPS61046. The schematic diagram is in the attachment. Could you please help to check it?
1.The BQ25302 schematic looks ok overall and does not have obvious issues. Please double check the custom schematic with typical application diagrams on the d/s and the EVM design.
2. For a standalone charger without power path as shown Figure 9-1. Typical Application Diagram (1-µH inductor is recommended), a load should not be connected at the BAT pin.
3. If V_SYS load needs to be supported, Figure 9-6. Typical Application Diagram with Power Path is recommended.
Ning.
