BQ40Z50-R1: SRP,SRN
Part Number: BQ40Z50-R1
Hello support team.
SRP and SRN of BQ40Z50-R1 are
The Absolute Maximum Ratings in the IC's datasheet is ±0.3V.
By design, the maximum voltage applied to SRP and SRN is 0.5V.
Is it possible to use it as is?
  • Hello Tatsuya,
    You should not apply above the absolute maximum rating or you could cause permanent damage to the part. 0.5V differential is too high to apply across the SRN/SRP pins.
    Sincerely,
    Wyatt Keller
