According to your input and output conditions, maybe you should choose a converter or module with an IC current of 8A-10A. I may recommend LM61480, LM61495 and their corresponding modules TPSM63608, TPSM63610. For details on how to use the BUCK converter to create an inverting power supply, you can refer to the application notes in the attachment. Hope this can help you. Thanks.
7774.Create an Inverting Power Supply Using Peak Current Mode Buck Converter.pdf6278.Working with Inverting Buck_Boost Converters.pdf
Aurora
I will close this thread due to no reply for a long time. If you have other questions in the future, you can ask them again in E2E. Thanks.
Aurora
