Other Parts Discussed in Thread: TPS50601-SP,
How will the TPS50601a_SP operate if the SYNC pin is pulled high (5V) through ~ 2kohms prior to Vcc coming up? This might occur during power-up where the SYNC source defaults high.
The datasheet recommends a 47k - 510k ohm resistor from SYNC to GND in order to use an external SYNC signal - will the TPS50601-SP properly sync to the incoming signal for the case described above (pulled high vs the 47k-510k resistor to GND)
Steve
