Hello Tier,
I have a question about the Valley current limit in TPS56C215. I'm afraid of misunderstanding, so I edited a figure in the E2E post for your reference. Can you tell me if the waveform below explains the Valley current limit during Overcurrent?Understanding valley current limit - Power management - Technical articles - TI E2E support forums
Also, can you tell me what is the Current Limit (Low side negative)? Is the current defined as the direction from the source to the Drain of the low side rectifier FET?
