Hi All,
I am using ISO5852 isolated gate driver in my inverter application. In that I have connected all the Fault signals together with a common pull up resistor to VCC. In internal circuit diagram of IC FLT pin is directly connected to VCC, it means when we will get FLT signal high it will pull downs supply voltage or it will gives only signal to us??
Vivek Gandham
