BQ40Z50-R2: Failed learning cycle at second relax, VOK never clear
Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: GPCRA0
1Charge Relax.gg.csv2235.log.log
At the second relax the VOK bit is never cleared even after REST is set. Logs attached.
  • Hello Riley,
    I will take a look at this thread by the end of day.
    Sincerely,
    Wyatt Keller
  • Thankyou Wyatt.
    To Update, I made the assumption that The learning cycle failed due to a charge timeout error. I disabled this protection and ran the learning cycle again. I began the second relax (after full charge) before leaving for the day. When I came back the VOK bit had cleared but it doesn't appear a QMax update has occurred. The [QMax] flag is in the same state and the Update Status register is still 04.
    Log and data memory from after test attached
    3542.log.log
    112(3,4).gg.csv
  • Hello Riley,
    I've been looking at the most recent log, I don't see any major issues with your testing. If you continue to perform the discharge are you able to get a Qmax update from the discharge portion of the learning cycle?
    If not then I would recommend using the GPCRA0 tool, it may be difficult to get the learning complete with LFP type chemistry so the tool may be easier.
    Sincerely,
    Wyatt Keller
  • Hi Wyatt,
    I have successfully generated a golden file using the GPCRA0 tool. After some testing it appears to have provided sufficient results for this stage of product development.
    I will likely attempt a learning cycle at a later date, hopefully that will go better..
    Kind Regards,
    Riley Beck
