The FS Manual mentions [SA_29] “The actuator has a pull-down resistance on its input pin connected to the (?) of the TPS6593x-Q1”. Is it the EN_DRV?
If so, then the data sheet specifies something different in ch. 6.1 table 6-2: “RECOMMENDED EXTERNAL PU/PD - none”. Which is correct?
