Part Number: TPS25750
Dear TI team,
After pulling my hair on some strange bugs (eg : https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1294435/tps25750-source-mode-gpio-direct-access/4913389#4913389)
I've noticed some strange behavior from your GUI TPS25750 Application Customization Tool 7.0.4.7 (I made sure to download again everything, to be up to date).
If I setup my config from the defaut EVM choice on question 1 (not selecting another choice), or if I select another choice before selecting again the Source/SinkTPS25750D/BQ (EVM config), the generated full-flash binary differs (sometimes, quite a lot).
If the config selected in the end is the same, shouldn't it generate the same binary ? And which one is the good one ??
Maybe you should look into that. I think the thread I linked above is because of that, I've selected the Source/Sink config after having selected a sink-only config, and some of the sink-only config remained so my TPS couldn't switch to source.
Here are some test configs and binary I've done to compare :
Feel free to contact me if you need more info.
Thanks and Regards,
Richard
