Hello Ti expert:
I want to use low test FET to control the mos switch, and I want to know whether DDSG, DCHG or CFETOFF,DFETOFF, should be used to control the FET. Or do we use both together? When I looked at the manual, I did not quite understand how to use the low test FET scheme, because I wanted the device to recognize and turn off the FET when the protection is triggered, and to use the host to control the FET in other states. Do you have any recommendations? Look forward to your reply, thank you!
