Other Parts Discussed in Thread: UCC2808-1
I use the chip UCC2808-2 and I would like to fix the duty cycle about ~40%. How to do it ?
I'm confused with COMP and CS pins functionnality. I read that "The CS pin is for duty-cycle control" (subject: UCC2808A-1: Open Loop Configuration) or "The duty is adjusted by COMP voltage" (subject : UCC2808-1: two questions about how to use).
I realized a lot of experiments. The most conclusive is : CS=not connected, FB=~0V (=it's the VCE voltage of NPN to realize a shutdown) and COMP=0.506mV (with potentiometer to tune the Vcomp). BUT I'm not confident about leaving CS unwired (!!!).
Do you have application note for a fix duty cycle ? Please can you give me your recommendation ?
Best regards
Eric
