Other Parts Discussed in Thread: LM5156,
Team,
Customer would like to implement a BOOST with LMG35xxx drieven by an analog controller.
Assuming that LM5156 would be used as controller what driver circuit would you recommend between LM5156 and LMG3522R030?
I tried to check different LMG35xx based TIDA/PMPs but it seems to often use an ISO7xxx output (powered by an 12V auxiliary supply) driven from an MCU PWM:
https://www.ti.com/reference-designs/index.html?login-check=true#search?login-check=truesearchkeywordLMG3522
Do you have an example for a "direct" drive from an analog controller?
Thanks in advance,
Anthony
