Other Parts Discussed in Thread: TMP103,
I need to know the UBM size of the component TPS22915BYFPR because I can't find it in the datasheet.
I attach an image to clarify what I mean.
Thank you
Hi Gianluca,
Welcome to e2e! Please see this post, can you derive the information you need from the resources here?
Patrick
Hi Patrick,
I read the post you suggested. I think that the package for TMP103 is the same as TPS22915. Can I assume UBM size = 0,21 mm also for TPS22915? Thank you for confirmation.
Gianluca
Hi Gianluca,
Yes, the package is similar - I believe that you can assume UBM size = 0.21mm.
Patrick
