TPS543320: Calculating Output Impedance modeled as a series RL circuit
Part Number: TPS543320
I am using Intel's Power Distribution Tool to model a PDN. I am trying to use the information in the datasheet to create a VRM model of this voltage regulator. There are 2 specific fields that call out a R_vrm and L_vrm which should be the equivalent series circuit of this regulator. What information should I be aware of in order to calculate these values?
Thank you,
