Other Parts Discussed in Thread: TPS65220
I am using TPS6521902RHBR variant in my custom board.
According to datasheet this PMIC should have I2C address = 0x30 by default, but instead it answer when probed on 0x24 address.
Using the same software on the devboard AM64-SK which mounts a TPS65220 the I2C address is correctly found to be 0x30.
Apart from the incorrect address being set, the PMIC seems to work as it should: it provides the correct voltages and I can correctly access all the registers with the new address.
Since the PMIC on our custom board has never been reprogrammed by us (we got this board assembled this week) I am puzzled by this situation.
Why is the address changed? Is it something that happens in factory when releasing the -02- variant or should this suggest a malfunction?
Thank you for your help,
Paolo Mattachini
