TPS23523: TIMER related question
Part Number: TPS23523
Team, We discussed about the device timer function in the thread before, it’s closed so I create this thread to further discuss. 1. The data sheet only gives the Vsns, tmr1 minimum and typical value, didn’t give maximum value. We still want to know the max value, which means the Vsns voltage that can trigger the timer. 2. We also want to know this spec across different samples, is there a plot to indicate this data?
Qiang
