Other Parts Discussed in Thread: BQSTUDIO, BQ34Z100
To whom it may concern:
The previous post is locked. https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1346324/bq34z100-g1-communication-stuck/5145142#5145142
We still have this issue, and the root cause is not clear yet. Our FAE should already passed all the files of this design to Evan. Do you need some samples to do further diagnostic?
Some more batteries are reported failed in the field, with the same issue: no communication, and I2C CLK line is pulled low (GND) inside the IC. This problem can be solved by hard reset of the IC.
We tried ESD with Fullsleep enabled, and no issue so far. Also our FAE mentioned if the fuel gauge is in ROM mode. First of all, the fuel gauge is sealed, so it should not get into ROM mode. So if the fuel gauge is in ROM mode, how can we communicate or send command to the fuel gauge?
Thank you!
Chen
