TPS628304: schematic check
Part Number: TPS628304
Hi
Could you help the check below TPS628304A schematic and any need adjust ,Thanks
AMD.pdf
    These 2 designs look ok.
    The diode on each of the PG pins may be pointed backwards, depending on what they are trying to do.  If they are trying to OR various PG signal with diodes, then the diodes should be reversed.
    Chris
