I have some DC-DC power regulator needs and I was hoping TI could recommend the best DC-DC non-isolated match. The input will be +5V.
Regulators will be managed/sequenced by the UCD9090-Q1
I am not understanding your question.
We need 5 devices or rails that match the above-mentioned specifications. The input for all of them will be 5v.
Hi Matthew,
I will check your feedback and get back to you next Monday.
BRs
Lucia
Hi Mattew,
Let me clarify, as you know, our device has input voltage range. For example, for TPSM863252 (the part you choose here), its input voltage range supports 3-17V. That's the reason why I also check with you about the input voltage range in actual application. For example. if your input voltage is only up to 6V, I can assign this thread to other teams who will be expert.
Thanks!
BRs
Lucia
Hi Mattew,
Reassigned and expert from low Vin team will give you response soon.
BRs
Lucia
Hi Mattew,
See the below recommendations,
0.8V, 4A, 3% DC accuracy, ramp up time ≤ 3ms
Performance device:
TPS62827 data sheet, product information and support | TI.com
TPS628304 data sheet, product information and support | TI.com
Low cost device:
TPS62A04(RTM in september)
1.2V, 500mA, 3% DC accuracy, ramp up time ≤ 5ms (maybe an LDO fed by 1.8V)
Performance device:
TPS62843 data sheet, product information and support | TI.com
Low cost device:
TPS62A01 data sheet, product information and support | TI.com
- 1.8V, 2A, 3% DC accuracy, ramp up time ≤ 3ms
- 3.3V, 2A, 3% DC accuracy, ramp up time ≤ 5ms
Performance device:
TPS62825 data sheet, product information and support | TI.com
Low cost device:
TPS62A02 data sheet, product information and support | TI.com
Thank you & regards,
Moheddin.
Hi Mattew,
0.88V, 25A, 3%(1%DC accuracy + 2% AC ripple) , step response 9A over 350ns, ramp up time ≤ 5ms.
Moheddin.
