Hello:
If PWM adjustment is not required for LM3405, first connect the EN pin to GND and turn off this function. If I only need to turn it on and off, then I can connect the switch button to the power input terminal to achieve it, right?
Hi Jimmy,
I am here to help you with your question.
Based on your words, you mean you do not need PWM dimming function, right? If so, you only need to tie the EN/DIM pin to VIN.
May I ask what you mean by 'switch button'?
Thank you!
Hi Qingwei:
I still need the LED driven switch function, but does not use PWM to adjust, only on and off. Therefore, they want to add a switch button at the power supply position to achieve on and off in conjunction with the conduction of the transistor. Please guide, thank you!!!
Hi Jimmy,
Got your idea.
In this case, you only need to always tie the EN/DIM pin with VIN. Then you could use the button on power rail you mentioned to control the device on/off by connecting/disconnecting the power supply.
Thank you!
Qingwei.
