UCC28180: Unencrypted lib file
Part Number: UCC28180
Other Parts Discussed in Thread: UCC28065
Hi Everyone,
I need Ucc28180 IC's Unencrypted lib file. If any one have kindly reply to me.
Hi, @Tony Hsu Did you got a ucc28180 Unencrypted lib file. Or how you solved gate signal error.
Are you getting GATE pulse signal in Runtime
Thanks Guys,
Suriya
  • We don't provide the unencrypted file in general. Instead, I suggest to compare your design with our reference first.
  • https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1039188/uc3825a-too-few-nodes-error-in-ltspice
    Kindly refer this page. In that page Generally they provided the unencrypted file. Then you also can make like that or can you send the file in personal chat.
    Also i need UCC28065 spice model, is that possible to get this one?
    I have UCC28180 lib file also that was encrypted. I made symbol for LTspice purpose and I'm including the lib file but while doing the simulation time i'm  getting "Too few nodes" error.
    Here I'm attached the circuit
    Tell me, how to resolve this error in LTspice.
    Suriya.
  • Hello Suriya,
    TI does not support LTspice models or modelling issues.
    Here is the UCC28180 system model .lib file:
    UCC28180_AVG(unencrypt).lib.txt
    * UCC28180
    * (C) Copyright 2014Texas Instruments Incorporated. All rights reserved.
    ** This model is designed as an aid for customers of Texas Instruments.
    ** TI and its licensors and suppliers make no warranties, either expressed
    ** or implied, with respect to this model, including the warranties of
    ** merchantability or fitness for a particular purpose.  The model is
    ** provided solely on an "as is" basis.  The entire risk as to its quality
    ** and performance is with the customer
    * This model is subject to change without notice. Texas Instruments
    * Incorporated is not responsible for updating this model.
    ** Released by: WEBENCH Design Center, Texas Instruments Inc.
    * Part: UCC28180
    * Date: 14APR2014
    * Model Type: AVERAGE
    * Simulator: PSPICE
    * Simulator Version: 16.2.0.p001
    * EVM Order Number: UCC28180EVM-573
    * EVM Users Guide: SLUUAT3B–October 2013–Revised December 2013
    * Datasheet: SLUSxxx – June 21, 2013
    * Model Version: Final 1.00
    * Updates:
    * Final 1.00
    * Release to Web.
    .SUBCKT UCC28180_AVG GATE GND ICOMP ISENSE VCOMP VSENSE
    E_E1         5 0 0 N1580156 1
    G_ABM2I8         0 ICOMP VALUE { LIMIT(( V(5)-V(27))*0.95m,-50u,50u)    }
    E_ABM5         M1 0 VALUE { IF(V(VCOMP) <1 , 0.068 , IF(V(VCOMP)<2 ,  0.156 *
    +  V(VCOMP) - 0.088 ,IF(V(VCOMP) <4.5 , 0.313 * V(VCOMP) - 0.401 , 1.007)))     }
    E_ABM1         27 0 VALUE { V(3)*V(M1)/(V(GAIN)+1u)    }
    E_E2         ICOMP 3 N1598706 0 1
    V_V4         NODE7 0 5
    D_D5         0 VCOMP _DCLAMP
    E_ABM3         N1597678 0 VALUE { -8.0284e-7*((Vin)**3)
    +  +5.6560e-4*((Vin)**2)-1.3507e-1*((Vin))+6.9512    }
    E_ABM7         N1580156 0 VALUE { (V(ISENSE)*2.5)    }
    E_ABM4         20 0 VALUE { (1 -(V(3))/(V(M2)/FREQ)-230N*FREQ)    }
    R_R1         0 3  100k TC=0,0
    D_D6         0 ICOMP _DZ
    E_ABM8         GAIN 0 VALUE { 1.4283e-07*((Vin)**3) -5.8598e-5*((Vin)**2) +
    +  0.036514*(Vin) -0.98469    }
    E_ABM6         M2 0 VALUE { IF(V(VCOMP) <0.5 , 0.01m , IF(V(VCOMP)< 4.6 ,
    +  0.1223MEG*(FREQ/65K) * (V(VCOMP) -0.5)*(V(VCOMP) -0.5) , 2.056MEG*(FREQ/65K)))
    G_ABM2I2         0 VCOMP VALUE { LIMIT(( V(NODE7)-V(VSENSE))*56u,-40u,40u)    }
    E_ABM2         GATE 0 VALUE { IF(V(20)>0.99 , 0.99 , IF(V(20)<1m , 1m , V(20)))
    V_V5         N1598706 0 -0.5
    .ENDS UCC28180_AVG
    .SUBCKT BOOST_CCM_DCM D GND Vin VOut
    E_ABM6         N1667239 0 VALUE { (V(VOUT) * (V(D)))    }
    G_ABMI1         N1667225 GND VALUE { (I(V_V4)*V(D))    }
    V_V4         VIN N1667225 0Vdc
    E_E1         N1667225 VOUT N1667239 GND -1
    .ENDS BOOST_CCM_DCM
    .model _DCLAMP d
    + bv=7
    + ibv=0.0001
    .model _DZ d
    + bv=7.2
    + ibv=5e-005
    .model IN5046 D
    .SUBCKT LDCR IN OUT
    + PARAMs:  L=1u DCR=0.01
    L	IN 1  {L}
    RDCR	1 OUT {DCR}
    .ENDS LDCR
    .SUBCKT CESR IN OUT
    + PARAMs:  C=100u ESR=0.01
    C	IN 1  {C}
    RESR	1 OUT {ESR}
    .ENDS CESR
    It can be viewed in Notepad.
    Simply remove the ".txt" suffix and it is the original .lib file.
    If you can analyze this model, you will see that the GATE output is a signal from 0 to 1V (approximately) which represents the duty cycle to be applied to the BOOSTCCMDCM block.  It is not a PWM signal.
    I explained how to derive a PWM signal from this GATE signal in my reply of July 16 to your previous E2E thread on this same topic:
    https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1387309/ucc28180-ucc28180_avg-cadence-simulation_-gate-signal-issues
    Please reread my suggestions carefully.
    Ulrich
