TPS25942A-Power block diagram.pdf
Dear Arush and TI Team
Thank you for your support so far.
This is regarding Oring IC TPS25942A,
1. As I said earlier, these ICs are giving problems in my design. I bypassed these ICs with a strap and my board is working(Schematic and block diagram attached for your reference).
2. In a fresh card, I bypassed board load and gave these oring ICs o/p to DC load. These ICs are working fine till 2A. I increased the load to 3.2A and found that both ICs went faulty and gave only .8V output and never came up. When I mount a fresh IC it will work till 2A.
But as per data sheet these ICs should support 5A load and we mounted Resistor Rilim as 17.8K.
Could you please analyse and update.
With Regards
Krishnam Raju M
