Other Parts Discussed in Thread: SN6501
hi team,
can you help to review the sch of the UCC5350MCDR here ?Customers reported that the UCC5350MCDR driver was powered by bootstrap mode with a power supply of 15V. When testing the output waveform on the secondary side, it was found to be normal at the beginning, but the output was turned off after a while (the primary side continued to transmit the wave). we used a multimeter to measure the secondary side power supply voltage and found that it was only have 11V. The bootstrap diode voltage drop was 1.7V. then we changed the power supply voltage to 16.5V, but the problem still occurred. What is the possible reason?
tks for the comments here.
