Other Parts Discussed in Thread: TPS25751
Dear Support TI,
I have a problem using TPS25751EVM, I'm supplying it with an PD adapter 20V 5A and I tried to use the TPS25751D as a source. The system work only if the output voltage is 5V, if the sink ask 20V the TPS will reset.
Attached the json code:
"questionnaire": {
"device": "TPS25751",
"answers": [
null,
1,
4,
4,
1,
0,
3,
0,
1,
1,
0,
null,
0,
0,
0,
0,
0,
0,
0
"vendorId": "0000",
"productId": "0000",
"version": "1.0.0.2"
"configuration": {
"data": {
"selected_ace": [
"register": 6,
"data": [
0,
0,
0,
0,
0,
0,
0,
0
"register": 22,
"data": [
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
3
"register": 40,
"data": [
2,
0,
47,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"register": 41,
"data": [
82,
80,
144,
3
"register": 50,
"data": [
2,
168,
42,
44,
145,
1,
32,
44,
65,
6,
0,
44,
177,
4,
0,
44,
65,
6,
0,
244,
65,
6,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"register": 51,
"data": [
4,
44,
145,
1,
16,
44,
209,
2,
0,
44,
177,
4,
0,
44,
65,
6,
0,
69,
65,
6,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"register": 55,
"data": [
62,
80,
20,
65,
144,
145,
1,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"register": 92,
"data": [
207,
12,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
4,
0,
0,
0,
4,
0,
0,
0,
0,
0,
0,
0,
4,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"register": 112,
"data": [
3
"register": 152,
"data": [
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
Can you help me with this?
Thank you
Stefano
