Dear team,
My customer met an issue with unused TS pin. They want to config TS_IGNORE as 1, however, since the TS_IGNORE is 0 by fault, under AC only condition (no battery), the charger is wake before the MCU, and with connections below they found Vsys and VBAT even reaches to 23.5V. so they want to know how to deal with the unused TS pin, should they make it float?
【Test results】:
condition: default regs setup, no load connected. no battery connected, AC connected
with R0550 populated, Vsys and Vbat reaches 23.5V (Customer want to know why)
with R0550 not populated, Vsys is 7.2V, VBat no output
Thank you
Charles
