I would like to design 7KW totem pole pfc using UCD3138
let me know feasilbility of design please
Thank you
venkatesh
Thank you
venkatesh
Venkatesh,
UCD3138 architecture supports totem pole PFC configuration. The power stage and driver stages needs to be accordingly designed based on the power levels.
Hemanth
based on the power levels-----Would you please tell me how much power can be designed by the chip?
Tom,
As UCD3138 is being a digital controller, there is no power limit as such that I know of that is by the controller. It is the power stage that is - topology, circuit design, component selection, layout, thermals are what would pose constraints on the power levels.
Hemanth
Hi Tom Tom &Hemanth Sreeperumbudur
Thanks for your valuable comment
I will check it
Thank you
venkatesh
Venkatesh,
If you are talking about DCM or Critical Mode Conduction control of PFC, yes UCD3138 can support this.
Please refer : https://www.ti.com/lit/an/slua708/slua708.pdf in full and section 5.3 specifically.
Hemanth
Hi hemnath,
Thank you for sharing ZVS at switching frequency
But i was mentioning Input current AC waveform zero crossing which is general issue of Totem pole PFC, hope you understand totem pole PFC sensing at input side
Thank you
venkatesh
Venkatesh,
You could refer to the article "How to reduce current spikes at AC zero-crossing for totem-pole PFC (https://www.ti.com/lit/an/slyt650/slyt650.pdf)". This is based on UCD3138 controller.
Hemanth
