I have same issue as https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1339054/tps65219-irq-issue, but there is no solution there, was this bug fixed?
Hi Anthony,
Sorry for the delayed response with my schedule and travel! I will look into this solution because I agree a floating IRQ isn’t ideal. I should be able to look into this by the end of next week & respond with a proper solution. Thank you for your patience!
Shree Ramamoorthy
just to anticipate your request, full boot log with pin crl debug turned on
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.10.09 06:51:47 =~=~=~=~=~=~=~=~=~=~=~= U-Boot SPL 2023.04-g7044504f44-dirty (Oct 08 2024 - 08:15:30 -0700) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 13408 bytes Trying to boot from MMC2 Authentication passed Authentication passed Authentication passed Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.10.0(debug):armbian NOTICE: BL31: Built : 11:41:26, Oct 7 2024 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x80080000 INFO: SPSR = 0x3c9 U-Boot SPL 2023.10-rc3-armbian-2023.10-rc3-S976f-P2dd6-H4074-V0b30-Bda0a-R448a (Oct 08 2024 - 08:15:35 -0700) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 1744 bytes Trying to boot from MMC2 single-pinctrl pinctrl@f4000: configuring pins for main-mmc1-default-pins single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 single-pinctrl pinctrl@f4000: reg/val 81fffb98a/0x00050000 am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-mmc-hs am654_sdhci mmc@fa00000: Couldn't find am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-ddr52 am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-hs200 am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-hs400 Authentication passed Authentication passed U-Boot 2023.10-rc3-armbian-2023.10-rc3-S976f-P2dd6-H4074-V0b30-Bda0a-R448a (Oct 08 2024 - 08:15:35 -0700) size=30, ptr=1fb0, limit=8000: 80b79f80 SoC: AM62X SR1.0 HS-FS Model: Texas Instruments AM625 SK DRAM: 1 GiB Bound device mod_exp_sw to root_driver bind node chosen Device 'chosen' has no compatible string bind node firmware Device 'firmware' has no compatible string bind node timer-cl0-cpu0 - attempt to match compatible string 'arm,armv8-timer' No match for node 'timer-cl0-cpu0' bind node pmu - attempt to match compatible string 'arm,cortex-a53-pmu' No match for node 'pmu' bind node bus@f0000 - attempt to match compatible string 'simple-bus' - found match at 'simple_bus': 'simple-bus' matches 'simple-bus' bind node bus@4000000 - attempt to match compatible string 'simple-bus' - found match at 'simple_bus': 'simple-bus' matches 'simple-bus' bind node pinctrl@4084000 - attempt to match compatible string 'pinctrl-single' - found match at 'single-pinctrl': 'pinctrl-single' matches 'pinctrl-single' Bound device wkup-uart0-default-pins to pinctrl@4084000 Bound device mcu_uart0-default-pins to pinctrl@4084000 Bound device pinctrl@4084000 to bus@4000000 bind node esm@4100000 - attempt to match compatible string 'ti,j721e-esm' No match for node 'esm@4100000' - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device bind node serial@4a00000 - attempt to match compatible string 'ti,am64-uart' - attempt to match compatible string 'ti,am654-uart' - found match at 'omap_serial': 'ti,omap2-uart' matches 'ti,am654-uart' - seq=0 Bound device serial@4a00000 to bus@4000000 - ignoring disabled device - ignoring disabled device - ignoring disabled device bind node interrupt-controller@4210000 - attempt to match compatible string 'ti,sci-intr' No match for node 'interrupt-controller@4210000' bind node gpio@4201000 - attempt to match compatible string 'ti,am64-gpio' - attempt to match compatible string 'ti,keystone-gpio' No match for node 'gpio@4201000' - ignoring disabled device Bound device bus@4000000 to bus@f0000 bind node bus@b00000 - attempt to match compatible string 'simple-bus' - found match at 'simple_bus': 'simple-bus' matches 'simple-bus' bind node syscon@43000000 - attempt to match compatible string 'syscon' - found match at 'syscon': 'syscon' matches 'syscon' bind node chipid@14 - attempt to match compatible string 'ti,am654-chipid' - found match at 'soc_ti_k3': 'ti,am654-chipid' matches 'ti,am654-chipid' Bound device chipid@14 to syscon@43000000 Bound device syscon@43000000 to bus@b00000 - ignoring disabled device - ignoring disabled device bind node rtc@2b1f0000 - attempt to match compatible string 'ti,am62-rtc' No match for node 'rtc@2b1f0000' - ignoring disabled device bind node temperature-sensor@b00000 - attempt to match compatible string 'ti,j7200-vtm' No match for node 'temperature-sensor@b00000' Bound device bus@b00000 to bus@f0000 bind node sram@70000000 - attempt to match compatible string 'mmio-sram' No match for node 'sram@70000000' bind node interrupt-controller@1800000 - attempt to match compatible string 'arm,gic-v3' No match for node 'interrupt-controller@1800000' bind node syscon@100000 - attempt to match compatible string 'syscon' - found match at 'syscon': 'syscon' matches 'syscon' bind node phy@4044 - attempt to match compatible string 'ti,am654-phy-gmii-sel' No match for node 'phy@4044' bind node clock@4130 - attempt to match compatible string 'ti,am62-epwm-tbclk' - attempt to match compatible string 'syscon' - found match at 'syscon': 'syscon' matches 'syscon' Bound device clock@4130 to syscon@100000 Bound device syscon@100000 to bus@f0000 bind node bus@48000000 - attempt to match compatible string 'simple-mfd' - found match at 'simple_bus': 'simple-bus' matches 'simple-mfd' bind node mailbox@4d000000 - attempt to match compatible string 'ti,am654-secure-proxy' - found match at 'k3-secure-proxy': 'ti,am654-secure-proxy' matches 'ti,am654-secure-proxy' Bound device mailbox@4d000000 to bus@48000000 bind node interrupt-controller@48000000 - attempt to match compatible string 'ti,sci-inta' No match for node 'interrupt-controller@48000000' bind node dma-controller@485c0100 - attempt to match compatible string 'ti,am64-dmss-bcdma' - found match at 'ti-udma': 'ti,am654-navss-main-udmap' matches 'ti,am64-dmss-bcdma' Bound device dma-controller@485c0100 to bus@48000000 bind node dma-controller@485c0000 - attempt to match compatible string 'ti,am64-dmss-pktdma' - found match at 'ti-udma': 'ti,am654-navss-main-udmap' matches 'ti,am64-dmss-pktdma' Bound device dma-controller@485c0000 to bus@48000000 Bound device bus@48000000 to bus@f0000 bind node system-controller@44043000 - attempt to match compatible string 'ti,k2g-sci' - found match at 'ti_sci': 'ti,k2g-sci' matches 'ti,k2g-sci' bind node power-controller - attempt to match compatible string 'ti,sci-pm-domain' - found match at 'ti-sci-pm-domains': 'ti,sci-pm-domain' matches 'ti,sci-pm-domain' Bound device power-controller to system-controller@44043000 bind node clock-controller - attempt to match compatible string 'ti,k2g-sci-clk' - found match at 'ti-sci-clk': 'ti,k2g-sci-clk' matches 'ti,k2g-sci-clk' Bound device clock-controller to system-controller@44043000 bind node reset-controller - attempt to match compatible string 'ti,sci-reset' - found match at 'ti-sci-reset': 'ti,sci-reset' matches 'ti,sci-reset' Bound device reset-controller to system-controller@44043000 Bound device system-controller@44043000 to bus@f0000 bind node crypto@40900000 - attempt to match compatible string 'ti,am62-sa3ul' No match for node 'crypto@40900000' - ignoring disabled device bind node pinctrl@f4000 - attempt to match compatible string 'pinctrl-single' - found match at 'single-pinctrl': 'pinctrl-single' matches 'pinctrl-single' Bound device main-uart0-default-pins to pinctrl@f4000 Bound device main-uart1-default-pins to pinctrl@f4000 Bound device main_uart2-default-pins to pinctrl@f4000 Bound device main_uart3-default-pins to pinctrl@f4000 Bound device main-uart5-pins-default to pinctrl@f4000 Bound device main-i2c0-default-pins to pinctrl@f4000 Bound device main-i2c1-default-pins to pinctrl@f4000 Bound device main-i2c2-default-pins to pinctrl@f4000 Bound device main-mmc0-default-pins to pinctrl@f4000 Bound device main-mmc1-default-pins to pinctrl@f4000 Bound device usr-led-default-pins to pinctrl@f4000 Bound device main-mdio1-default-pins to pinctrl@f4000 Bound device main-usb1-default-pins to pinctrl@f4000 Bound device main-spi1-default-pins to pinctrl@f4000 Bound device main-mcasp1-default-pins to pinctrl@f4000 Bound device pinctrl@f4000 to bus@f0000 bind node esm@420000 - attempt to match compatible string 'ti,j721e-esm' No match for node 'esm@420000' bind node timer@2400000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2400000' bind node timer@2410000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2410000' bind node timer@2420000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2420000' bind node timer@2430000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2430000' bind node timer@2440000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2440000' bind node timer@2450000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2450000' bind node timer@2460000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2460000' bind node timer@2470000 - attempt to match compatible string 'ti,am654-timer' No match for node 'timer@2470000' bind node serial@2800000 - attempt to match compatible string 'ti,am64-uart' - attempt to match compatible string 'ti,am654-uart' - found match at 'omap_serial': 'ti,omap2-uart' matches 'ti,am654-uart' - seq=2 Bound device serial@2800000 to bus@f0000 bind node serial@2810000 - attempt to match compatible string 'ti,am64-uart' - attempt to match compatible string 'ti,am654-uart' - found match at 'omap_serial': 'ti,omap2-uart' matches 'ti,am654-uart' - seq=4 Bound device serial@2810000 to bus@f0000 bind node serial@2820000 - attempt to match compatible string 'ti,am64-uart' - attempt to match compatible string 'ti,am654-uart' - found match at 'omap_serial': 'ti,omap2-uart' matches 'ti,am654-uart' - seq=5 Bound device serial@2820000 to bus@f0000 bind node serial@2830000 - attempt to match compatible string 'ti,am64-uart' - attempt to match compatible string 'ti,am654-uart' - found match at 'omap_serial': 'ti,omap2-uart' matches 'ti,am654-uart' - seq=6 Bound device serial@2830000 to bus@f0000 - ignoring disabled device bind node serial@2850000 - attempt to match compatible string 'ti,am64-uart' - attempt to match compatible string 'ti,am654-uart' - found match at 'omap_serial': 'ti,omap2-uart' matches 'ti,am654-uart' - seq=3 Bound device serial@2850000 to bus@f0000 - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device bind node spi@20110000 - attempt to match compatible string 'ti,am654-mcspi' - attempt to match compatible string 'ti,omap4-mcspi' No match for node 'spi@20110000' - ignoring disabled device bind node interrupt-controller@a00000 - attempt to match compatible string 'ti,sci-intr' No match for node 'interrupt-controller@a00000' bind node gpio@600000 - attempt to match compatible string 'ti,am64-gpio' - attempt to match compatible string 'ti,keystone-gpio' No match for node 'gpio@600000' bind node gpio@601000 - attempt to match compatible string 'ti,am64-gpio' - attempt to match compatible string 'ti,keystone-gpio' No match for node 'gpio@601000' bind node mmc@fa10000 - attempt to match compatible string 'ti,am62-sdhci' - found match at 'am654_sdhci': 'ti,am654-sdhci-5.1' matches 'ti,am62-sdhci' - seq=0 Bound device mmc@fa10000.blk to mmc@fa10000 Bound device mmc@fa10000.bootdev to mmc@fa10000 Bound device mmc@fa10000 to bus@f0000 bind node mmc@fa00000 - attempt to match compatible string 'ti,am62-sdhci' - found match at 'am654_sdhci': 'ti,am654-sdhci-5.1' matches 'ti,am62-sdhci' - seq=1 Bound device mmc@fa00000.blk to mmc@fa00000 Bound device mmc@fa00000.bootdev to mmc@fa00000 Bound device mmc@fa00000 to bus@f0000 - ignoring disabled device bind node dwc3-usb@f900000 - attempt to match compatible string 'ti,am62-usb' No match for node 'dwc3-usb@f900000' bind node dwc3-usb@f910000 - attempt to match compatible string 'ti,am62-usb' No match for node 'dwc3-usb@f910000' bind node ethernet@8000000 - attempt to match compatible string 'ti,am642-cpsw-nuss' - found match at 'am65_cpsw_nuss': 'ti,am654-cpsw-nuss' matches 'ti,am642-cpsw-nuss' bind node ethernet-ports Device 'ethernet-ports' has no compatible string - ignoring disabled device bind node cpts@3d000 - attempt to match compatible string 'ti,j721e-cpts' No match for node 'cpts@3d000' Bound device ethernet@8000000 to bus@f0000 bind node spinlock@2a000000 - attempt to match compatible string 'ti,am64-hwspinlock' No match for node 'spinlock@2a000000' bind node mailbox@29000000 - attempt to match compatible string 'ti,am64-mailbox' No match for node 'mailbox@29000000' - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device bind node watchdog@e000000 - attempt to match compatible string 'ti,j7-rti-wdt' No match for node 'watchdog@e000000' bind node watchdog@e010000 - attempt to match compatible string 'ti,j7-rti-wdt' No match for node 'watchdog@e010000' - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device - ignoring disabled device Bound device bus@f0000 to root_driver bind node thermal-zones Device 'thermal-zones' has no compatible string bind node cpus Device 'cpus' has no compatible string bind node opp-table - attempt to match compatible string 'operating-points-v2-ti-cpu' No match for node 'opp-table' bind node l2-cache0 - attempt to match compatible string 'cache' No match for node 'l2-cache0' bind node aliases Device 'aliases' has no compatible string bind node memory@80000000 Device 'memory@80000000' has no compatible string bind node reserved-memory Device 'reserved-memory' has no compatible string bind node leds - attempt to match compatible string 'gpio-leds' No match for node 'leds' bind node clk-0 - attempt to match compatible string 'fixed-clock' - found match at 'fixed_clock': 'fixed-clock' matches 'fixed-clock' Bound device clk-0 to root_driver bind node sound - attempt to match compatible string 'simple-audio-card' No match for node 'sound' bind node regulator-0 - attempt to match compatible string 'regulator-fixed' No match for node 'regulator-0' bind node regulator-1 - attempt to match compatible string 'regulator-fixed' No match for node 'regulator-1' bind node regulator-2 - attempt to match compatible string 'regulator-fixed' No match for node 'regulator-2' bind node regulator-5 - attempt to match compatible string 'regulator-fixed' No match for node 'regulator-5' bind node binman Device 'binman' has no compatible string bind node __symbols__ Device '__symbols__' has no compatible string bind node optee - attempt to match compatible string 'linaro,optee-tz' No match for node 'optee' bind node psci - attempt to match compatible string 'arm,psci-1.0' - found match at 'psci': 'arm,psci' matches 'arm,psci-1.0' PSCI System Reset was not bound. Bound device psci to root_driver Bound device bootstd to root_driver Bound device efi to bootstd Bound device extlinux to bootstd Bound device vbe_simple to bootstd binman: Selected image node 'custMpk' Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) Looking for mailbox@4d000000 Looking for mailbox@4d000000 - checking mailbox@4d000000 - result for mailbox@4d000000: mailbox@4d000000 (ret=0) - result for mailbox@4d000000: mailbox@4d000000 (ret=0) Looking for mailbox@4d000000 Looking for mailbox@4d000000 - checking mailbox@4d000000 - result for mailbox@4d000000: mailbox@4d000000 (ret=0) - result for mailbox@4d000000: mailbox@4d000000 (ret=0) ti_sci system-controller@44043000: ti_sci_of_to_info: Acquiring notify channel failed. ret = -61 Looking for power-controller Looking for power-controller - checking power-controller - result for power-controller: power-controller (ret=0) - result for power-controller: power-controller (ret=0) single-pinctrl pinctrl@f4000: 171 pins single-pinctrl pinctrl@f4000: configuring pins for main-uart0-default-pins single-pinctrl pinctrl@f4000: reg/val 0x00000000000f41c8/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f41cc/0x00010000 Core: 55 devices, 20 uclasses, devicetree: separate Initializing EFI driver framework Adding EFI driver 'EFI block driver' MMC: 0 - 0 'mmc@fa10000' - found Looking for power-controller Looking for power-controller - checking power-controller - result for power-controller: power-controller (ret=0) - result for power-controller: power-controller (ret=0) Sending event 4/(unknown) to spy 'efi_disk add' single-pinctrl pinctrl@f4000: configuring pins for main-mmc0-default-pins single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4220/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4218/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4214/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4210/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f420c/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4208/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4204/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4200/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f41fc/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f41f8/0x00050000 Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-sd-hs am654_sdhci mmc@fa10000: Couldn't find <NULL> am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-sdr12 am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-sdr25 am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-sdr50 am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-ddr50 am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-sdr104 am654_sdhci mmc@fa10000: Couldn't find ti,otap-del-sel-hs400 Sending event 4/(unknown) to spy 'efi_disk add' 1 - 0 'mmc@fa10000' - 1 'mmc@fa00000' - found Looking for power-controller Looking for power-controller - checking power-controller - result for power-controller: power-controller (ret=0) - result for power-controller: power-controller (ret=0) Sending event 4/(unknown) to spy 'efi_disk add' single-pinctrl pinctrl@f4000: configuring pins for main-mmc1-default-pins single-pinctrl pinctrl@f4000: reg/val 0x00000000000f423c/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4234/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4230/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f422c/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4228/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4224/0x00050000 single-pinctrl pinctrl@f4000: reg/val 0x00000000000f4240/0x00050000 Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-mmc-hs am654_sdhci mmc@fa00000: Couldn't find <NULL> am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-ddr52 am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-hs200 am654_sdhci mmc@fa00000: Couldn't find ti,otap-del-sel-hs400 Sending event 4/(unknown) to spy 'efi_disk add' 2 - 0 'mmc@fa10000' - 1 'mmc@fa00000' - not found mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Looking for power-controller Looking for power-controller - checking power-controller - result for power-controller: power-controller (ret=0) - result for power-controller: power-controller (ret=0) Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) Looking for power-controller Looking for power-controller - checking power-controller - result for power-controller: power-controller (ret=0) - result for power-controller: power-controller (ret=0) Looking for clock-controller Looking for clock-controller - checking clock-controller - result for clock-controller: clock-controller (ret=0) - result for clock-controller: clock-controller (ret=0) Bound device port@1.bootdev to port@1 Bound device port@1 to ethernet@8000000 am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000 Sending event 4/(unknown) to spy 'efi_disk add' Hit any key to stop autoboot: 17 16 15 0 => boot selecting mode MMC legacy (freq : 0 MHz) selecting mode MMC legacy (freq : 50 MHz) trying mode SD High Speed (50MHz) width 4 (at 50 MHz) selecting mode SD High Speed (50MHz) (freq : 50 MHz) Bound device mmc@fa00000.blk:1 to mmc@fa00000.blk Sending event 4/(unknown) to spy 'efi_disk add' Bound device mmc@fa00000.blk:2 to mmc@fa00000.blk Sending event 4/(unknown) to spy 'efi_disk add' Bound device mmc@fa00000.blk:3 to mmc@fa00000.blk Sending event 4/(unknown) to spy 'efi_disk add' Bound device mmc@fa00000.blk:4 to mmc@fa00000.blk Sending event 4/(unknown) to spy 'efi_disk add' Sending event 4/(unknown) to spy 'efi_disk add' <2, 0, 1024> <8, 0, 64> <6264, 256, 128> <2, 0, 1024> <8, 0, 64> <6264, 256, 128> <2, 0, 1024> <8, 0, 64> <4008, 256, 128> switch to partitions #0, OK mmc1 is current device selecting mode MMC legacy (freq : 50 MHz) selecting mode MMC legacy (freq : 50 MHz) trying mode SD High Speed (50MHz) width 4 (at 50 MHz) selecting mode SD High Speed (50MHz) (freq : 50 MHz) SD/MMC found on device 1 FAT read(sect=513), clust_size=8, read_size=8 FAT read(sect=513), clust_size=8, read_size=8 Failed to load 'boot.scr' FAT read(sect=513), clust_size=8, read_size=8 FAT read(sect=513), clust_size=8, read_size=8 dev=mmc, devnr=1, path=uEnv.txt, buffer=0000000082000000, size=ce Wrong FIT format: not a flattened device tree (err=-9) - not remembering image 206 bytes read in 16 ms (11.7 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... FAT read(sect=513), clust_size=8, read_size=8 FAT read(sect=513), clust_size=8, read_size=8 dev=mmc, devnr=1:1, path=/uInitrd, buffer=0000000088080000, size=a51806 Wrong FIT format: not a flattened device tree (err=-9) - not remembering image 10819590 bytes read in 470 ms (22 MiB/s) FAT read(sect=513), clust_size=8, read_size=8 FAT read(sect=513), clust_size=8, read_size=8 dev=mmc, devnr=1:1, path=/Image, buffer=0000000082000000, size=1406a00 - boot device /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b,0000000000000000)/VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b,6a00000000000000)/SD(1)/SD(1)/HD(1,MBR,0xf71f68e7,0x2000,0x80000) - image /\Image 20998656 bytes read in 895 ms (22.4 MiB/s) FAT read(sect=513), clust_size=8, read_size=8 FAT read(sect=553), clust_size=8, read_size=8 FAT read(sect=561), clust_size=8, read_size=8 FAT read(sect=513), clust_size=8, read_size=8 FAT read(sect=553), clust_size=8, read_size=8 FAT read(sect=561), clust_size=8, read_size=8 dev=mmc, devnr=1:1, path=/dtb/ti/k3-am625-sk.dtb, buffer=0000000088000000, size=c042 FIT check error -99 - not remembering image 49218 bytes read in 35 ms (1.3 MiB/s) Working FDT set to 88000000 FIT check error -99 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Ramdisk to 8f5ae000, end 8ffff806 ... OK Loading Device Tree to 000000008f49e000, end 000000008f5adfff ... OK Working FDT set to 8f49e000 Starting kernel ... Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' chipid@14: When removing: flags=4600, drv->flags=0, err=-129 syscon@43000000: When removing: flags=4600, drv->flags=0, err=-129 bus@b00000: When removing: flags=4600, drv->flags=4, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' mailbox@4d000000: When removing: flags=4600, drv->flags=0, err=-129 bus@48000000: When removing: flags=4600, drv->flags=4, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' power-controller: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' clock-controller: When removing: flags=4600, drv->flags=0, err=-129 system-controller@44043000: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' main-uart0-default-pins: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' main-mmc0-default-pins: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' main-mmc1-default-pins: When removing: flags=4600, drv->flags=0, err=-129 pinctrl@f4000: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' serial@2800000: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa10000: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:1: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:2: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:3: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:4: When removing: flags=4600, drv->flags=0, err=-129 mmc@fa00000.blk: When removing: flags=4600, drv->flags=0, err=-129 mmc@fa00000: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' ethernet@8000000: When removing: flags=4600, drv->flags=0, err=-129 bus@f0000: When removing: flags=4600, drv->flags=4, err=-129 root_driver: When removing: flags=4600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' chipid@14: When removing: flags=600, drv->flags=0, err=-129 syscon@43000000: When removing: flags=600, drv->flags=0, err=-129 bus@b00000: When removing: flags=600, drv->flags=4, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' mailbox@4d000000: When removing: flags=600, drv->flags=0, err=-129 bus@48000000: When removing: flags=600, drv->flags=4, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' power-controller: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' clock-controller: When removing: flags=600, drv->flags=0, err=-129 system-controller@44043000: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' main-uart0-default-pins: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' main-mmc0-default-pins: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' main-mmc1-default-pins: When removing: flags=600, drv->flags=0, err=-129 pinctrl@f4000: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' serial@2800000: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa10000: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:1: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:2: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:3: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' mmc@fa00000.blk:4: When removing: flags=600, drv->flags=0, err=-129 mmc@fa00000.blk: When removing: flags=600, drv->flags=0, err=-129 mmc@fa00000: When removing: flags=600, drv->flags=0, err=-129 Sending event 5/(unknown) to spy 'efi_disk del' ethernet@8000000: When removing: flags=600, drv->flags=0, err=-129 bus@f0000: When removing: flags=600, drv->flags=4, err=-129 root_driver: When removing: flags=600, drv->flags=0, err=-129 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.54-edge-k3 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #2 SMP PREEMPT Fri Oct 4 07:30:05 PDT 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: 0x000000009ca00000..0x000000009cafffff (1024 KiB) map non-reusable ramoops@9ca00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9db00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-dma-memory@9db00000 [ 0.000000] OF: reserved mem: 0x000000009e780000..0x000000009e7fffff (512 KiB) nomap non-reusable tfa@9e780000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009dafffff] [ 0.000000] node 0: [mem 0x000000009db00000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000bfffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] cma: Reserved 32 MiB at 0x00000000bcc00000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s43752 r8192 d29976 u81920 [ 0.000000] pcpu-alloc: s43752 r8192 d29976 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=f71f68e7-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x00000000b8c00000-0x00000000bcc00000] (64MB) [ 0.000000] Memory: 859188K/1048576K available (12608K kernel code, 1242K rwdata, 4088K rodata, 2432K init, 457K bss, 156620K reserved, 32768K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008533] Console: colour dummy device 80x25 [ 0.013134] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023818] pid_max: default: 32768 minimum: 301 [ 0.028618] LSM: initializing lsm=capability,integrity [ 0.033980] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.041557] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.051547] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [ 0.058884] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [ 0.066861] rcu: Hierarchical SRCU implementation. [ 0.071769] rcu: Max phase no-delay instances is 1000. [ 0.077398] Platform MSI: msi-controller@1820000 domain created [ 0.083681] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.093065] EFI services will not be available. [ 0.097917] smp: Bringing up secondary CPUs ... [ 0.103270] Detected VIPT I-cache on CPU1 [ 0.103359] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.103377] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.103437] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.103577] smp: Brought up 1 node, 2 CPUs [ 0.132973] SMP: Total of 2 processors activated. [ 0.137786] CPU features: detected: 32-bit EL0 Support [ 0.143061] CPU features: detected: CRC32 instructions [ 0.148391] CPU: All CPU(s) started at EL2 [ 0.152592] alternatives: applying system-wide alternatives [ 0.159938] devtmpfs: initialized [ 0.170203] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.180227] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.188376] pinctrl core: initialized pinctrl subsystem [ 0.194413] DMI not present or invalid. [ 0.199225] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.206243] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.213572] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.221574] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.229759] audit: initializing netlink subsys (disabled) [ 0.235515] audit: type=2000 audit(0.144:1): state=initialized audit_enabled=0 res=1 [ 0.236019] thermal_sys: Registered thermal governor 'step_wise' [ 0.243465] thermal_sys: Registered thermal governor 'power_allocator' [ 0.249657] cpuidle: using governor menu [ 0.260486] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.267495] ASID allocator initialised with 65536 entries [ 0.284931] Modules: 27520 pages in range for non-PLT usage [ 0.284951] Modules: 519040 pages in range for PLT usage [ 0.291582] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.304001] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.310411] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.317351] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.323760] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.330699] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.337107] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.344047] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.351983] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.361046] reg-fixed-voltage regulator-vcc-3v3-main: using DT '/regulator-vcc-3v3-main' for '(null)' GPIO lookup [ 0.361542] iommu: Default domain type: Translated [ 0.371588] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vcc-3v3-main[0]' [ 0.376506] iommu: DMA domain TLB invalidation policy: strict mode [ 0.386116] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vcc-3v3-main[0]' [ 0.392729] SCSI subsystem initialized [ 0.401930] reg-fixed-voltage regulator-vcc-3v3-main: using lookup tables for GPIO lookup [ 0.405952] libata version 3.00 loaded. [ 0.414132] reg-fixed-voltage regulator-vcc-3v3-main: No GPIO consumer (null) found [ 0.418238] usbcore: registered new interface driver usbfs [ 0.431486] usbcore: registered new interface driver hub [ 0.436954] usbcore: registered new device driver usb [ 0.442587] pps_core: LinuxPPS API ver. 1 registered [ 0.447668] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.457019] PTP clock support registered [ 0.461225] EDAC MC: Ver: 3.0.0 [ 0.464988] scmi_core: SCMI protocol bus registered [ 0.470335] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.477469] FPGA manager framework [ 0.481064] Advanced Linux Sound Architecture Driver Initialized. [ 0.488497] clocksource: Switched to clocksource arch_sys_counter [ 0.495051] VFS: Disk quotas dquot_6.6.0 [ 0.499121] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.512766] NET: Registered PF_INET protocol family [ 0.517963] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.526570] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 0.535195] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.543134] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.551108] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.558779] TCP: Hash tables configured (established 8192 bind 8192) [ 0.565471] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.572279] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.579667] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.585976] RPC: Registered named UNIX socket transport module. [ 0.592060] RPC: Registered udp transport module. [ 0.596871] RPC: Registered tcp transport module. [ 0.601680] RPC: Registered tcp-with-tls transport module. [ 0.607288] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.613880] NET: Registered PF_XDP protocol family [ 0.618800] PCI: CLS 0 bytes, default 64 [ 0.623037] Unpacking initramfs... [ 0.626606] Initramfs unpacking failed: invalid magic at start of compressed archive [ 0.627670] Initialise system trusted keyrings [ 0.640154] workingset: timestamp_bits=46 max_order=18 bucket_order=0 [ 0.641491] Freeing initrd memory: 10564K [ 0.647198] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.657264] NFS: Registering the id_resolver key type [ 0.662469] Key type id_resolver registered [ 0.666748] Key type id_legacy registered [ 0.670865] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.677722] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.715619] Key type asymmetric registered [ 0.719822] Asymmetric key parser 'x509' registered [ 0.724874] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.732660] io scheduler mq-deadline registered [ 0.737313] io scheduler kyber registered [ 0.744217] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.750713] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.763917] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.780465] loop: module loaded [ 0.784210] zram: Added device: zram0 [ 0.789033] megasas: 07.725.01.00-rc1 [ 0.794745] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 0.801009] mdio_bus fixed-0: No GPIO consumer reset found [ 0.808051] tun: Universal TUN/TAP device driver, 1.6 [ 0.813931] thunder_xcv, ver 1.0 [ 0.817270] thunder_bgx, ver 1.0 [ 0.820589] nicpf, ver 1.0 [ 0.823489] e1000: Intel(R) PRO/1000 Network Driver [ 0.828476] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.834390] e1000e: Intel(R) PRO/1000 Network Driver [ 0.839472] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 0.845554] igb: Intel(R) Gigabit Ethernet Network Driver [ 0.851076] igb: Copyright (c) 2007-2014 Intel Corporation. [ 0.856794] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.863204] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.869362] sky2: driver version 1.30 [ 0.874015] VFIO - User Level meta-driver version: 0.3 [ 0.879833] usbcore: registered new interface driver usb-storage [ 0.886529] i2c_dev: i2c /dev entries driver [ 0.892441] sdhci: Secure Digital Host Controller Interface driver [ 0.898821] sdhci: Copyright(c) Pierre Ossman [ 0.903491] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.909699] leds-gpio leds: using DT '/leds/led-0' for '(null)' GPIO lookup [ 0.916846] leds-gpio leds: No GPIO consumer (null) found [ 0.922650] ledtrig-cpu: registered to indicate activity on CPUs [ 0.929082] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.936044] usbcore: registered new interface driver usbhid [ 0.941747] usbhid: USB HID core driver [ 0.946996] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.956053] optee: probing for conduit method. [ 0.960617] optee: api uid mismatch [ 0.964176] optee: probe of firmware:optee failed with error -22 [ 0.971907] Initializing XFRM netlink socket [ 0.976365] NET: Registered PF_PACKET protocol family [ 0.981638] Key type dns_resolver registered [ 0.994150] registered taskstats version 1 [ 0.998507] Loading compiled-in X.509 certificates [ 1.011560] reg-fixed-voltage regulator-vcc-3v3-sys: using DT '/regulator-vcc-3v3-sys' for '(null)' GPIO lookup [ 1.014319] leds-gpio leds: using DT '/leds/led-0' for '(null)' GPIO lookup [ 1.022583] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vcc-3v3-sys[0]' [ 1.029161] leds-gpio leds: No GPIO consumer (null) found [ 1.038660] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vcc-3v3-sys[0]' [ 1.044811] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.053590] reg-fixed-voltage regulator-vcc-3v3-sys: using lookup tables for GPIO lookup [ 1.053597] reg-fixed-voltage regulator-vcc-3v3-sys: No GPIO consumer (null) found [ 1.088954] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=9, ret=-19 [ 1.100116] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=15, ret=-19 [ 1.110832] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=16, ret=-19 [ 1.121546] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=17, ret=-19 [ 1.132249] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=36, clk=18, ret=-19 [ 1.143889] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=9, ret=-19 [ 1.155043] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=15, ret=-19 [ 1.165755] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=16, ret=-19 [ 1.176456] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=17, ret=-19 [ 1.187162] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=37, clk=18, ret=-19 [ 1.198798] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=9, ret=-19 [ 1.209945] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=15, ret=-19 [ 1.220652] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=16, ret=-19 [ 1.231340] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=17, ret=-19 [ 1.242038] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=38, clk=18, ret=-19 [ 1.253703] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=9, ret=-19 [ 1.264881] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=15, ret=-19 [ 1.275592] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=16, ret=-19 [ 1.286290] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=17, ret=-19 [ 1.296990] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=39, clk=18, ret=-19 [ 1.308668] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=9, ret=-19 [ 1.319833] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=15, ret=-19 [ 1.330544] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=16, ret=-19 [ 1.341246] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=17, ret=-19 [ 1.351949] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=40, clk=18, ret=-19 [ 1.363622] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=9, ret=-19 [ 1.374783] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=15, ret=-19 [ 1.385512] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=16, ret=-19 [ 1.396215] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=17, ret=-19 [ 1.406931] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=41, clk=18, ret=-19 [ 1.418601] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=9, ret=-19 [ 1.429770] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=15, ret=-19 [ 1.440492] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=16, ret=-19 [ 1.451205] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=17, ret=-19 [ 1.461908] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=42, clk=18, ret=-19 [ 1.473577] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=9, ret=-19 [ 1.484777] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=15, ret=-19 [ 1.495492] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=16, ret=-19 [ 1.506197] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=17, ret=-19 [ 1.516909] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=43, clk=18, ret=-19 [ 1.547588] i2c i2c-0: using DT '/bus@f0000/i2c@20000000' for 'scl' GPIO lookup [ 1.555126] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/bus@f0000/i2c@20000000[0]' [ 1.565102] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/bus@f0000/i2c@20000000[0]' [ 1.574984] i2c i2c-0: using lookup tables for GPIO lookup [ 1.580595] i2c i2c-0: No GPIO consumer scl found [ 1.585419] i2c i2c-0: using DT '/bus@f0000/i2c@20000000' for 'sda' GPIO lookup [ 1.592902] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/bus@f0000/i2c@20000000[0]' [ 1.602873] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/bus@f0000/i2c@20000000[0]' [ 1.612756] i2c i2c-0: using lookup tables for GPIO lookup [ 1.618365] i2c i2c-0: No GPIO consumer sda found [ 1.623855] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2 [ 1.658491] gpiochip_find_base: found new base at 512 [ 1.665323] gpio gpiochip0: (tps65219-gpio): added GPIO chardev (254:0) [ 1.672182] gpio gpiochip0: registered GPIOs 512 to 514 on tps65219-gpio [ 1.679520] omap_i2c 20000000.i2c: bus 0 rev0.12 at 100 kHz [ 1.686774] i2c i2c-1: using DT '/bus@f0000/i2c@20010000' for 'scl' GPIO lookup [ 1.694320] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/bus@f0000/i2c@20010000[0]' [ 1.704307] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/bus@f0000/i2c@20010000[0]' [ 1.714191] i2c i2c-1: using lookup tables for GPIO lookup [ 1.719802] i2c i2c-1: No GPIO consumer scl found [ 1.724632] i2c i2c-1: using DT '/bus@f0000/i2c@20010000' for 'sda' GPIO lookup [ 1.732117] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/bus@f0000/i2c@20010000[0]' [ 1.742090] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/bus@f0000/i2c@20010000[0]' [ 1.751970] i2c i2c-1: using lookup tables for GPIO lookup [ 1.757585] i2c i2c-1: No GPIO consumer sda found [ 1.762705] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.768779] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.777182] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.786443] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.796376] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.805201] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.816423] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.827694] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.838449] omap8250 4a00000.serial: using DT '/bus@f0000/bus@4000000/serial@4a00000' for 'rs485-term' GPIO lookup [ 1.849139] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/bus@f0000/bus@4000000/serial@4a00000[0]' [ 1.860986] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/bus@f0000/bus@4000000/serial@4a00000[0]' [ 1.872736] omap8250 4a00000.serial: using lookup tables for GPIO lookup [ 1.879592] omap8250 4a00000.serial: No GPIO consumer rs485-term found [ 1.886271] omap8250 4a00000.serial: using DT '/bus@f0000/bus@4000000/serial@4a00000' for 'rs485-rx-during-tx' GPIO lookup [ 1.897577] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpios' property of node '/bus@f0000/bus@4000000/serial@4a00000[0]' [ 1.910132] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpio' property of node '/bus@f0000/bus@4000000/serial@4a00000[0]' [ 1.922601] omap8250 4a00000.serial: using lookup tables for GPIO lookup [ 1.929457] omap8250 4a00000.serial: No GPIO consumer rs485-rx-during-tx found [ 1.937069] 4a00000.serial: ttyS1 at MMIO 0x4a00000 (irq = 285, base_baud = 3000000) is a 8250 [ 1.947388] omap8250 2800000.serial: using DT '/bus@f0000/serial@2800000' for 'rs485-term' GPIO lookup [ 1.957011] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/bus@f0000/serial@2800000[0]' [ 1.967824] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/bus@f0000/serial@2800000[0]' [ 1.978537] omap8250 2800000.serial: using lookup tables for GPIO lookup [ 1.985394] omap8250 2800000.serial: No GPIO consumer rs485-term found [ 1.992072] omap8250 2800000.serial: using DT '/bus@f0000/serial@2800000' for 'rs485-rx-during-tx' GPIO lookup [ 2.002312] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpios' property of node '/bus@f0000/serial@2800000[0]' [ 2.013824] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpio' property of node '/bus@f0000/serial@2800000[0]' [ 2.025220] omap8250 2800000.serial: using lookup tables for GPIO lookup [ 2.032103] omap8250 2800000.serial: No GPIO consumer rs485-rx-during-tx found [ 2.039724] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 286, base_baud = 3000000) is a 8250 [ 2.048613] printk: console [ttyS2] enabled [ 2.048613] printk: console [ttyS2] enabled [ 2.057068] printk: bootconsole [ns16550a0] disabled [ 2.057068] printk: bootconsole [ns16550a0] disabled [ 2.069585] omap8250 2810000.serial: using DT '/bus@f0000/serial@2810000' for 'rs485-term' GPIO lookup [ 2.078971] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/bus@f0000/serial@2810000[0]' [ 2.089517] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/bus@f0000/serial@2810000[0]' [ 2.099993] omap8250 2810000.serial: using lookup tables for GPIO lookup [ 2.106710] omap8250 2810000.serial: No GPIO consumer rs485-term found [ 2.113296] omap8250 2810000.serial: using DT '/bus@f0000/serial@2810000' for 'rs485-rx-during-tx' GPIO lookup [ 2.123326] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpios' property of node '/bus@f0000/serial@2810000[0]' [ 2.134581] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpio' property of node '/bus@f0000/serial@2810000[0]' [ 2.145722] omap8250 2810000.serial: using lookup tables for GPIO lookup [ 2.152417] omap8250 2810000.serial: No GPIO consumer rs485-rx-during-tx found [ 2.159834] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 287, base_baud = 3000000) is a 8250 [ 2.169278] omap8250 2820000.serial: failed to get alias [ 2.175230] omap8250 2830000.serial: failed to get alias [ 2.181752] omap8250 2850000.serial: using DT '/bus@f0000/serial@2850000' for 'rs485-term' GPIO lookup [ 2.191100] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/bus@f0000/serial@2850000[0]' [ 2.201633] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/bus@f0000/serial@2850000[0]' [ 2.212061] omap8250 2850000.serial: using lookup tables for GPIO lookup [ 2.218753] omap8250 2850000.serial: No GPIO consumer rs485-term found [ 2.225273] omap8250 2850000.serial: using DT '/bus@f0000/serial@2850000' for 'rs485-rx-during-tx' GPIO lookup [ 2.235272] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpios' property of node '/bus@f0000/serial@2850000[0]' [ 2.246480] of_get_named_gpiod_flags: can't parse 'rs485-rx-during-tx-gpio' property of node '/bus@f0000/serial@2850000[0]' [ 2.257597] omap8250 2850000.serial: using lookup tables for GPIO lookup [ 2.264288] omap8250 2850000.serial: No GPIO consumer rs485-rx-during-tx found [ 2.271710] 2850000.serial: ttyS3 at MMIO 0x2850000 (irq = 290, base_baud = 3000000) is a 8250 [ 2.282433] reg-fixed-voltage regulator-vdd-core: using DT '/regulator-vdd-core' for '(null)' GPIO lookup [ 2.282485] reg-fixed-voltage regulator-vcc-1v8: using DT '/regulator-vcc-1v8' for '(null)' GPIO lookup [ 2.292154] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vdd-core[0]' [ 2.302389] leds-gpio leds: using DT '/leds/led-0' for '(null)' GPIO lookup [ 2.310539] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vdd-core[0]' [ 2.317485] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vcc-1v8[0]' [ 2.326644] reg-fixed-voltage regulator-vdd-core: using lookup tables for GPIO lookup [ 2.335437] reg-fixed-voltage regulator-vdd-lpddr4: using DT '/regulator-vdd-lpddr4' for '(null)' GPIO lookup [ 2.343387] reg-fixed-voltage regulator-vddr-core: using DT '/regulator-vddr-core' for '(null)' GPIO lookup [ 2.353073] leds-gpio leds: No GPIO consumer (null) found [ 2.362908] reg-fixed-voltage regulator-vdd-core: No GPIO consumer (null) found [ 2.368373] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vdd-lpddr4[0]' [ 2.375596] reg-fixed-voltage regulator-vdda-1v8: using DT '/regulator-vdda-1v8' for '(null)' GPIO lookup [ 2.384742] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vcc-1v8[0]' [ 2.394421] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vddr-core[0]' [ 2.403315] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vdd-lpddr4[0]' [ 2.412429] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vdda-1v8[0]' [ 2.421988] reg-fixed-voltage regulator-vcc-1v8: using lookup tables for GPIO lookup [ 2.430746] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vddr-core[0]' [ 2.438281] reg-fixed-voltage regulator-vdd-lpddr4: using lookup tables for GPIO lookup [ 2.447843] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-vdda-1v8[0]' [ 2.455325] gpiochip_find_base: found new base at 515 [ 2.464250] reg-fixed-voltage regulator-vddr-core: using lookup tables for GPIO lookup [ 2.469423] reg-fixed-voltage regulator-vcc-1v8: No GPIO consumer (null) found [ 2.477530] reg-fixed-voltage regulator-vdda-1v8: using lookup tables for GPIO lookup [ 2.484495] sdhci-am654 fa10000.mmc: using DT '/bus@f0000/mmc@fa10000' for 'cd' GPIO lookup [ 2.492603] sdhci-am654 fa20000.mmc: using DT '/bus@f0000/mmc@fa20000' for 'wp' GPIO lookup [ 2.500688] reg-fixed-voltage regulator-vdd-lpddr4: No GPIO consumer (null) found [ 2.508956] reg-fixed-voltage regulator-vddr-core: No GPIO consumer (null) found [ 2.516391] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/bus@f0000/mmc@fa10000[0]' [ 2.523892] reg-fixed-voltage regulator-vdda-1v8: No GPIO consumer (null) found [ 2.533339] gpio gpiochip1: (4201000.gpio): added GPIO chardev (254:1) [ 2.540667] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/mmc@fa20000[0]' [ 2.547274] gpio gpiochip1: registered GPIOs 515 to 538 on 4201000.gpio [ 2.556784] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/mmc@fa20000[0]' [ 2.563307] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/bus@f0000/mmc@fa10000[0]' [ 2.572805] sdhci-am654 fa20000.mmc: using lookup tables for GPIO lookup [ 2.582465] sdhci-am654 fa10000.mmc: using lookup tables for GPIO lookup [ 2.588979] sdhci-am654 fa20000.mmc: No GPIO consumer wp found [ 2.595641] sdhci-am654 fa10000.mmc: No GPIO consumer cd found [ 2.602313] mmc2: CQHCI version 5.10 [ 2.607338] sdhci-am654 fa10000.mmc: using DT '/bus@f0000/mmc@fa10000' for 'wp' GPIO lookup [ 2.612752] gpiochip_find_base: found new base at 539 [ 2.619291] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/mmc@fa10000[0]' [ 2.624968] gpio gpiochip2: (600000.gpio): added GPIO chardev (254:2) [ 2.633905] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/mmc@fa10000[0]' [ 2.640725] gpio gpiochip2: registered GPIOs 539 to 630 on 600000.gpio [ 2.649830] sdhci-am654 fa10000.mmc: using lookup tables for GPIO lookup [ 2.660575] gpiochip_find_base: found new base at 631 [ 2.663015] sdhci-am654 fa10000.mmc: No GPIO consumer wp found [ 2.668519] gpio gpiochip3: (601000.gpio): added GPIO chardev (254:3) [ 2.680448] gpio gpiochip3: registered GPIOs 631 to 682 on 601000.gpio [ 2.680504] mmc0: CQHCI version 5.10 [ 2.689436] reg-fixed-voltage regulator-vdd-mmc1: using DT '/regulator-vdd-mmc1' for '(null)' GPIO lookup [ 2.691115] pinctrl-single f4000.pinctrl: pin PIN80 already requested by 600000.gpio; cannot claim for leds [ 2.700240] pinctrl-single f4000.pinctrl: pin PIN82 already requested by 600000.gpio; cannot claim for regulator-vpp-1v8 [ 2.710685] pinctrl-single f4000.pinctrl: pin-80 (leds) status -22 [ 2.720984] pinctrl-single f4000.pinctrl: pin PIN93 already requested by 600000.gpio; cannot claim for regulator-vcc-5v0 [ 2.727076] pinctrl-single f4000.pinctrl: could not request pin 80 (PIN80) from group usr-led-pins-default on device pinctrl-single [ 2.737839] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit [ 2.749714] leds-gpio leds: Error applying setting, reverse things back [ 2.750224] gpio-regulator regulator-vddshv-sdio: using DT '/regulator-vddshv-sdio' for '(null)' GPIO lookup [ 2.757344] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-vdd-mmc1[0]' [ 2.766391] of_get_named_gpiod_flags: parsed 'gpios' property of node '/regulator-vddshv-sdio[0]' - status (0) [ 2.774048] pinctrl-single f4000.pinctrl: pin-82 (regulator-vpp-1v8) status -22 [ 2.782775] gpio gpiochip2: Persistence not supported for GPIO 31 [ 2.793552] clk: Disabling unused clocks [ 2.800069] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 2.806162] pinctrl-single f4000.pinctrl: pin-93 (regulator-vcc-5v0) status -22 [ 2.810764] of_get_named_gpiod_flags: parsed 'gpio' property of node '/regulator-vdd-mmc1[0]' - status (0) [ 2.817834] gpio-regulator regulator-vddshv-sdio: using DT '/regulator-vddshv-sdio' for 'enable' GPIO lookup [ 2.824940] gpio gpiochip3: Persistence not supported for GPIO 49 [ 2.834641] pinctrl-single f4000.pinctrl: could not request pin 93 (PIN93) from group vcc-5v0-pins-default on device pinctrl-single [ 2.845153] pinctrl-single f4000.pinctrl: could not request pin 82 (PIN82) from group vpp-1v8-pins-default on device pinctrl-single [ 2.851197] reg-fixed-voltage regulator-vcc-5v0: Error applying setting, reverse things back [ 2.862409] reg-fixed-voltage regulator-vpp-1v8: Error applying setting, reverse things back [ 2.862484] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/regulator-vddshv-sdio[0]' [ 2.878084] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=43, clk=18, ret=-19 [ 2.882777] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/regulator-vddshv-sdio[0]' [ 2.891306] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=43, clk=17, ret=-19 [ 2.901149] gpio-regulator regulator-vddshv-sdio: using lookup tables for GPIO lookup [ 2.911570] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=43, clk=16, ret=-19 [ 2.921270] gpio-regulator regulator-vddshv-sdio: No GPIO consumer enable found [ 2.931758] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=43, clk=15, ret=-19 [ 2.967871] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=43, clk=9, ret=-19 [ 2.978673] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=42, clk=18, ret=-19 [ 2.989353] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=42, clk=17, ret=-19 [ 2.999970] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=42, clk=16, ret=-19 [ 3.010527] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=42, clk=15, ret=-19 [ 3.021256] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=42, clk=9, ret=-19 [ 3.031919] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=41, clk=18, ret=-19 [ 3.042386] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=41, clk=17, ret=-19 [ 3.052897] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=41, clk=16, ret=-19 [ 3.063328] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=41, clk=15, ret=-19 [ 3.073977] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=41, clk=9, ret=-19 [ 3.084618] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=40, clk=18, ret=-19 [ 3.095007] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=40, clk=17, ret=-19 [ 3.105395] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=40, clk=16, ret=-19 [ 3.115787] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=40, clk=15, ret=-19 [ 3.126394] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=40, clk=9, ret=-19 [ 3.136990] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=39, clk=18, ret=-19 [ 3.147381] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=39, clk=17, ret=-19 [ 3.157775] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=39, clk=16, ret=-19 [ 3.168174] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=39, clk=15, ret=-19 [ 3.178813] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=39, clk=9, ret=-19 [ 3.189426] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=38, clk=18, ret=-19 [ 3.199834] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=38, clk=17, ret=-19 [ 3.210287] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=38, clk=16, ret=-19 [ 3.220680] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=38, clk=15, ret=-19 [ 3.231290] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=38, clk=9, ret=-19 [ 3.241900] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=37, clk=18, ret=-19 [ 3.250841] mmc2: Failed to initialize a non-removable card [ 3.252288] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=37, clk=17, ret=-19 [ 3.268271] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=37, clk=16, ret=-19 [ 3.278664] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=37, clk=15, ret=-19 [ 3.289364] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=37, clk=9, ret=-19 [ 3.300036] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=36, clk=18, ret=-19 [ 3.310432] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=36, clk=17, ret=-19 [ 3.320845] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=36, clk=16, ret=-19 [ 3.331274] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=36, clk=15, ret=-19 [ 3.341982] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=36, clk=9, ret=-19 [ 3.352932] ALSA device list: [ 3.355979] No soundcards found. [ 3.359703] sdhci-am654 fa00000.mmc: using DT '/bus@f0000/mmc@fa00000' for 'cd' GPIO lookup [ 3.368125] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/bus@f0000/mmc@fa00000[0]' [ 3.378269] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/bus@f0000/mmc@fa00000[0]' [ 3.387910] sdhci-am654 fa00000.mmc: using lookup tables for GPIO lookup [ 3.388020] mmc0: Command Queue Engine enabled [ 3.394640] sdhci-am654 fa00000.mmc: No GPIO consumer cd found [ 3.399090] mmc0: new HS200 MMC card at address 0001 [ 3.404929] sdhci-am654 fa00000.mmc: using DT '/bus@f0000/mmc@fa00000' for 'wp' GPIO lookup [ 3.410707] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 3.418238] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/mmc@fa00000[0]' [ 3.432383] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/mmc@fa00000[0]' [ 3.432740] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 3.441908] sdhci-am654 fa00000.mmc: using lookup tables for GPIO lookup [ 3.447883] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 3.453551] sdhci-am654 fa00000.mmc: No GPIO consumer wp found [ 3.459215] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0) [ 3.464821] mmc1: CQHCI version 5.10 [ 3.515207] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 3.523195] Waiting for root device PARTUUID=f71f68e7-02... [ 3.593552] mmc1: new ultra high speed SDR104 SDHC card at address b36e [ 3.601395] mmcblk1: mmc1:b36e SDABC 29.1 GiB [ 3.608399] mmcblk1: p1 p2 p3 p4 [ 3.903632] EXT4-fs (mmcblk1p2): recovery complete [ 3.910409] EXT4-fs (mmcblk1p2): mounted filesystem 0a86461a-8760-4564-b450-cba10a2a1323 r/w with writeback data mode. Quota mode: none. [ 3.922759] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.959426] devtmpfs: mounted [ 3.964339] Freeing unused kernel memory: 2432K [ 3.968981] Run /sbin/init as init process [ 3.973074] with arguments: [ 3.976031] /sbin/init [ 3.978731] with environment: [ 3.981864] HOME=/ [ 3.984213] TERM=linux [ 4.136544] random: crng init done [ 6.996035] systemd[1]: System time before build time, advancing clock. [ 7.281602] NET: Registered PF_INET6 protocol family [ 7.287649] Segment Routing with IPv6 [ 7.291394] In-situ OAM (IOAM) with IPv6 [ 7.584701] systemd[1]: systemd 256.6-1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT +LIBARCHIVE) [ 7.617423] systemd[1]: Detected architecture arm64. Welcome to AmaSone 24.11.0-trunk sid! [ 7.683078] systemd[1]: Hostname set to <amasone-visitor>. [ 7.981557] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 8.277769] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported. [ 10.021715] (sd-exec-[84]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1. [ 10.294841] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway. [ 10.864974] systemd[1]: Queued start job for default target graphical.target. [ 10.912220] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ OK ] Created slice system-getty.slice - Slice /system/getty. [ 10.942233] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ OK ] Created slice system-modprobe.slice - Slice /system/modprobe. [ 10.969983] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ OK ] Created slice system-serial\x2dgetslice - Slice /system/serial-getty. [ 11.002089] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck. [ OK ] Created slice system-systemd\x2dfsslice - Slice /system/systemd-fsck. [ 11.032214] systemd[1]: Created slice user.slice - User and Session Slice. [ OK ] Created slice user.slice - User and Session Slice. [ 11.057820] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch. [ OK ] Started systemd-ask-password-consoequests to Console Directory Watch. [ 11.085216] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ OK ] Started systemd-ask-password-wall.d Requests to Wall Directory Watch. [ 11.114097] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc). [ 11.134275] systemd[1]: Expecting device dev-disk-by\x2dlabel-armbi_data.device - /dev/disk/by-label/armbi_data... Expecting device dev-disk-by\x2dla - /dev/disk/by-label/armbi_data... [ 11.160875] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2... Expecting device dev-ttyS2.device - /dev/ttyS2... [ 11.185073] systemd[1]: Reached target remote-fs.target - Remote File Systems. [ OK ] Reached target remote-fs.target - Remote File Systems. [ 11.208970] systemd[1]: Reached target slices.target - Slice Units. [ OK ] Reached target slices.target - Slice Units. [ 11.233017] systemd[1]: Reached target swap.target - Swaps. [ OK ] Reached target swap.target - Swaps. [ 11.256871] systemd[1]: Reached target time-set.target - System Time Set. [ OK ] Reached target time-set.target - System Time Set. [ 11.282627] systemd[1]: Listening on syslog.socket - Syslog Socket. [ OK ] Listening on syslog.socket - Syslog Socket. [ 11.315308] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption. [ OK ] Listening on systemd-creds.socket - Credential Encryption/Decryption. [ 11.341859] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ OK ] Listening on systemd-initctl.socke- initctl Compatibility Named Pipe. [ 11.369921] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ OK ] Listening on systemd-journald-dev-socket - Journal Socket (/dev/log). [ 11.397874] systemd[1]: Listening on systemd-journald.socket - Journal Sockets. [ OK ] Listening on systemd-journald.socket - Journal Sockets. [ 11.422729] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket. [ OK ] Listening on systemd-networkd.socket - Network Service Netlink Socket. [ 11.449116] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.462991] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 11.477152] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ OK ] Listening on systemd-udevd-control.socket - udev Control Socket. [ 11.501797] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ OK ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 11.537251] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System... Mounting dev-hugepages.mount - Huge Pages File System... [ 11.569049] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 11.609084] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock... Mounting run-lock.mount - Legacy Locks Directory /run/lock... [ 11.643628] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 11.685398] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 11.706463] systemd[1]: Started amasone-boot-start.service - AmaSone boot run tasks. [ OK ] Started amasone-boot-start.service - AmaSone boot run tasks. [ 11.742663] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... Starting fake-hwclock-load.service - Restore the current clock... [ 11.812249] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... Starting keyboard-setup.service - Set the console keyboard layout... [ 11.869622] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... Starting kmod-static-nodes.serviceeate List of Static Device Nodes... [ 11.906174] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... Starting modprobe@configfs.service - Load Kernel Module configfs... [ 11.961402] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... Starting modprobe@drm.service - Load Kernel Module drm... [ 11.993432] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... Starting modprobe@efi_pstore.servi - Load Kernel Module efi_pstore... [ 12.021443] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... Starting modprobe@fuse.service - Load Kernel Module fuse... [ 12.055196] systemd[1]: netplan-ovs-cleanup.service - OpenVSwitch configuration for cleanup was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/ovs-vsctl). [ 12.077210] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). [ 12.169405] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... Starting systemd-modules-load.service - Load Kernel Modules... [ 12.193173] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.210669] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 12.242321] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials... Starting systemd-udev-load-credentLoad udev Rules from Credentials... [ 12.308060] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 12.338262] fuse: init (API version 7.39) [ 12.378067] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ OK ] Mounted dev-hugepages.mount - Huge Pages File System. [ 12.401780] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ OK ] Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 12.425952] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ OK ] Mounted run-lock.mount - Legacy Locks Directory /run/lock. [ 12.460019] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ OK ] Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 12.487918] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 12.497849] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ OK ] Finished fake-hwclock-load.service - Restore the current clock. [ 12.532248] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ OK ] Finished kmod-static-nodes.serviceCreate List of Static Device Nodes. [ 12.560201] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 12.568841] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ OK ] Finished modprobe@configfs.service - Load Kernel Module configfs. [ 12.602624] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 12.611399] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ OK ] Finished modprobe@drm.service - Load Kernel Module drm. [ 12.641565] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 12.650525] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ OK ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 12.679582] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 12.687902] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ OK ] Finished modprobe@fuse.service - Load Kernel Module fuse. [ 12.715940] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ OK ] Finished systemd-modules-load.service - Load Kernel Modules. [ 12.749036] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 12.815971] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 12.858118] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 12.896770] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... Starting systemd-remount-fs.servicunt Root and Kernel File Systems... [ 12.973912] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... Starting systemd-sysctl.service - Apply Kernel Variables... [ 13.025293] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully... Starting systemd-tmpfiles-setup-de Device Nodes in /dev gracefully... [ 13.066511] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ OK ] Finished keyboard-setup.service - Set the console keyboard layout. [ 13.117964] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials. [ OK ] Finished systemd-udev-load-credent- Load udev Rules from Credentials. [ 13.175683] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ OK ] Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 13.209788] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ OK ] Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 13.261498] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ OK ] Finished systemd-sysctl.service - Apply Kernel Variables. [ 13.652248] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ OK ] Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 13.811112] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully. [ OK ] Finished systemd-tmpfiles-setup-deic Device Nodes in /dev gracefully. [ 15.905101] EXT4-fs (mmcblk1p2): re-mounted 0a86461a-8760-4564-b450-cba10a2a1323 r/w. Quota mode: none. [* ] (1 of 3) Job systemd-remount-fs.service/start running (5s / no limit) [ 15.939412] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ OK ] Finished systemd-remount-fs.servicmount Root and Kernel File Systems. [ 16.035287] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 16.050196] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 16.072646] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed... Starting systemd-random-seed.service - Load/Save OS Random Seed... [ 16.097545] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 16.129134] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... Starting systemd-tmpfiles-setup-deeate Static Device Nodes in /dev... [ 16.157120] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 16.253828] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ OK ] Finished systemd-tmpfiles-setup-deCreate Static Device Nodes in /dev. [ 16.281938] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ OK ] Reached target local-fs-pre.targetPreparation for Local File Systems. [ 16.345014] systemd[1]: Mounting tmp.mount - /tmp... Mounting tmp.mount - /tmp... [ 16.410014] systemd[1]: Mounting var-tmp.mount - /var/tmp... Mounting var-tmp.mount - /var/tmp... [ 16.444175] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... Starting systemd-udevd.service - Rager for Device Events and Files... [ 16.486997] systemd[1]: Mounted tmp.mount - /tmp. [ OK ] Mounted tmp.mount - /tmp. [ 16.516144] systemd[1]: Mounted var-tmp.mount - /var/tmp. [ OK ] Mounted var-tmp.mount - /var/tmp. [ 16.559928] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed. [ OK ] Finished systemd-random-seed.service - Load/Save OS Random Seed. [ 16.585981] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [** ] (1 of 3) Job dev-ttyS2.device/start running (7s / 1min 30s) [ 18.989180] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ OK ] Started systemd-udevd.service - Ruanager for Device Events and Files. [ 19.042631] systemd[1]: Starting systemd-networkd.service - Network Configuration... Starting systemd-networkd.service - Network Configuration... [ 19.364770] systemd[1]: Found device dev-ttyS2.device - /dev/ttyS2. [ OK ] Found device dev-ttyS2.device - /dev/ttyS2. [ 20.293585] at24 0-0051: supply vcc not found, using dummy regulator [ 20.302708] at24 0-0051: using DT '/bus@f0000/i2c@20000000/eeprom@51' for 'wp' GPIO lookup [ 20.311160] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/i2c@20000000/eeprom@51[0]' [ 20.321807] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/i2c@20000000/eeprom@51[0]' [ 20.332293] at24 0-0051: using lookup tables for GPIO lookup [ 20.337982] at24 0-0051: No GPIO consumer wp found [ 20.343047] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write [ 20.716378] rtc-ti-k3 2b1f0000.rtc: Clock rate 32552 is not 32768! Could misbehave! [ 20.716560] wm8904 1-001a: supply DCVDD not found, using dummy regulator [ 20.731497] wm8904 1-001a: supply DBVDD not found, using dummy regulator [ 20.738800] wm8904 1-001a: supply AVDD not found, using dummy regulator [ 20.746530] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ 20.751869] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:32 UTC (32) [ 20.760751] wm8904 1-001a: supply CPVDD not found, using dummy regulator [ 20.767549] wm8904 1-001a: supply MICVDD not found, using dummy regulator [ 20.774387] rtc-ti-k3 2b1f0000.rtc: using DT '/bus@f0000/bus@b00000/rtc@2b1f0000' for 'wp' GPIO lookup [ 20.783892] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/bus@f0000/bus@b00000/rtc@2b1f0000[0]' [ 20.794563] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/bus@f0000/bus@b00000/rtc@2b1f0000[0]' [ 20.805291] rtc-ti-k3 2b1f0000.rtc: using lookup tables for GPIO lookup [ 20.812097] rtc-ti-k3 2b1f0000.rtc: No GPIO consumer wp found [ 20.818623] wm8904 1-001a: revision A [ 20.873839] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector [ 21.045597] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 21.054832] tidss 30200000.dss: [drm] No compatible format found [ 21.063749] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ 21.199779] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 21.246040] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 21.252858] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 21.354430] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Listening on systemd-rfkill.socketll Switch Status /dev/rfkill Watch. [ 21.436389] asoc-simple-card sound: using DT '/sound' for 'simple-audio-card,hp-det' GPIO lookup [ 21.445557] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpios' property of node '/sound[0]' [ 21.455769] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [ 21.465865] asoc-simple-card sound: using lookup tables for GPIO lookup [ 21.472540] asoc-simple-card sound: No GPIO consumer simple-audio-card,hp-det found [ 21.480272] asoc-simple-card sound: using DT '/sound' for 'simple-audio-card,mic-det' GPIO lookup [ 21.489212] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpios' property of node '/sound[0]' [ 21.499498] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [ 21.509638] asoc-simple-card sound: using lookup tables for GPIO lookup [ 21.516304] asoc-simple-card sound: No GPIO consumer simple-audio-card,mic-det found [ 21.852870] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget. [ OK ] Reached target usb-gadget.target - Hardware activated USB gadget. [ 22.001935] systemd[1]: Found device dev-disk-by\x2dlabel-armbi_data.device - /dev/disk/by-label/armbi_data. [ OK ] Found device dev-disk-by\x2dlabel-ce - /dev/disk/by-label/armbi_data. [ 22.039550] systemd[1]: Starting systemd-fsck@dev-disk-by\x2dlabel-armbi_data.service - File System Check on /dev/disk/by-label/armbi_data... Starting systemd-fsck@dev-disk-by\on /dev/disk/by-label/armbi_data... [ 22.415537] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 22.421370] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 22.429337] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports [ 22.435416] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010 [ 22.444916] xhci-hcd xhci-hcd.3.auto: irq 481, io mem 0x31100000 [ 22.452093] hub 1-0:1.0: USB hub found [ 22.456008] hub 1-0:1.0: 1 port detected [ 22.712639] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 22.932075] hub 1-1:1.0: USB hub found [ 22.936343] hub 1-1:1.0: 4 ports detected [ 23.018833] systemd[1]: amasone-boot-start.service: Deactivated successfully. [ 23.332551] usb 1-1.3: new high-speed USB device number 3 using xhci-hcd [ 23.497902] systemd[1]: Started systemd-networkd.service - Network Configuration. [ OK ] Started systemd-networkd.service 23.507910] hub 1-1.3:1.0: USB hub found m - Network Configuration. [ 23.515650] hub 1-1.3:1.0: 4 ports detected [ 23.515733] systemd[1]: Starting systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd... Starting systemd-networkd-persistetent Storage in systemd-networkd... [ 23.820545] usb 1-1.3.2: new high-speed USB device number 4 using xhci-hcd [ 24.024870] systemd[1]: Finished systemd-networkd-persistent-storage.service - Enable Persistent Storage in systemd-networkd. [ 24.036375] usb 1-1.1: new high-speed USB device number 5 using xhci-hcd [ OK ] Finished systemd-networkd-persisteistent Storage in systemd-networkd. [ 24.171737] usb-storage 1-1.1:1.0: USB Mass Storage device detected [ 24.179261] scsi host0: usb-storage 1-1.1:1.0 [ 24.503149] usbcore: registered new interface driver cdc_ether [ 24.581365] cdc_ncm 1-1.3.2:2.0: MAC-Address: 6c:1f:f7:0b:46:93 [ 24.587356] cdc_ncm 1-1.3.2:2.0: setting rx_max = 16384 [ 24.592882] cdc_ncm 1-1.3.2:2.0: setting tx_max = 16384 [ 24.599187] cdc_ncm 1-1.3.2:2.0 eth0: register 'cdc_ncm' at usb-xhci-hcd.3.auto-1.3.2, CDC NCM (NO ZLP), 6c:1f:f7:0b:46:93 [ 24.610508] usbcore: registered new interface driver cdc_ncm [ 24.811471] cdc_ncm 1-1.3.2:2.0 enx6c1ff70b4693: renamed from eth0 [ 25.173194] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc). [ 25.193342] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 25.214327] scsi 0:0:0:0: Direct-Access USB SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6 [ 25.223658] systemd[1]: Started amasone-boot-start.service - AmaSone boot run tasks. [ OK ] Started amasone-boot-start.service - AmaSone boot run tasks. [ 25.242875] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock... Starting fake-hwclock-load.service - Restore the current clock... [ 25.283735] sd 0:0:0:0: [sda] 965246976 512-byte logical blocks: (494 GB/460 GiB) [ 25.293673] sd 0:0:0:0: [sda] Write Protect is off [ 25.299459] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 25.302652] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 Starting modprobe@efi_pstore.servi - Lo[ 25.319692] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67). ad Kernel Module efi_pstore... [ 25.321789] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 25.370453] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [ 25.386318] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 25.401627] sda: sda1 [ 25.404865] sd 0:0:0:0: [sda] Attached SCSI removable disk [ 25.409526] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [ 25.431414] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 25.447390] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki). [ 25.465894] systemd[1]: fake-hwclock-load.service: Deactivated successfully. [ 25.475397] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock. [ OK ] Finished fake-hwclock-load.service systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [0m - Restore the current clock. [ 25.498157] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ OK ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 25.519519] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 25.535814] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 25.846080] systemd[1]: Finished systemd-fsck@dev-disk-by\x2dlabel-armbi_data.service - File System Check on /dev/disk/by-label/armbi_data. [ OK ] Finished systemd-fsck@dev-disk-by\k on /dev/disk/by-label/armbi_data. [ 25.878407] systemd[1]: home.mount: Directory /home to mount over is not empty, mounting anyway. [ 25.891942] systemd[1]: Mounting home.mount - /home... Mounting home.mount - /home... [ 26.526687] EXT4-fs (mmcblk1p4): mounted filesystem 53842319-a99f-4e1b-8bba-efd452752da3 r/w with writeback data mode. Quota mode: none. [ 26.546923] systemd[1]: Mounted home.mount - /home. [ OK ] Mounted home.mount - /home. [ 26.561821] systemd[1]: Reached target local-fs.target - Local File Systems. [ OK ] Reached target local-fs.target - Local File Systems. [ 26.660309] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management. [ OK ] Listening on systemd-sysext.socket System Extension Image Management. [ 26.694090] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... Starting armbian-zram-config.service - Armbian ZRAM config... [ 26.729396] systemd[1]: Starting console-setup.service - Set console font and keymap... Starting console-setup.service - Set console font and keymap... [ 26.761402] systemd[1]: ldconfig.service - Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met. [ 26.897160] systemd[1]: systemd-binfmt.service - Set Up Additional Binary Formats was skipped because of an unmet condition check (ConditionPathIsMountPoint=/proc/sys/fs/binfmt_misc). [ 26.913963] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id). [ 26.933739] systemd[1]: amasone-boot-start.service: Deactivated successfully. [ 27.164084] systemd[1]: Finished console-setup.service - Set console font and keymap. [ OK ] Finished console-setup.service - Set console font and keymap. [ 28.218871] zram0: detected capacity change from 0 to 904952 [ 28.318675] Adding 452472k swap on /dev/zram0. Priority:5 extents:1 across:452472k SS [ 28.354248] zram: Added device: zram1 [ 28.688715] zram1: detected capacity change from 0 to 102400 [ 28.788351] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ OK ] Finished armbian-zram-config.service - Armbian ZRAM config. [ 28.822972] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... Starting armbian-ramlog.service - Armbian memory supported logging... [ 29.024124] EXT4-fs (zram1): mounted filesystem 4a35d388-dc8e-4194-9354-cd743a7c115f r/w without journal. Quota mode: none. [ 30.698004] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ OK ] Finished armbian-ramlog.service - Armbian memory supported logging. [ 30.738690] systemd[1]: Starting systemd-journald.service - Journal Service... Starting systemd-journald.service - Journal Service... [ 30.934236] systemd-journald[309]: Collecting audit messages is disabled. [ 31.095983] systemd[1]: Started systemd-journald.service - Journal Service. [ OK ] Started systemd-journald.service - Journal Service. Starting systemd-journal-flush.sersh Journal to Persistent Storage... [ 31.350899] systemd-journald[309]: Received client request to flush runtime journal. [ OK ] Finished systemd-journal-flush.serlush Journal to Persistent Storage. Starting systemd-tmpfiles-setup.seate System Files and Directories... [ OK ] Finished systemd-tmpfiles-setup.sereate System Files and Directories. Starting systemd-resolved.service - Network Name Resolution... Starting systemd-update-utmp.serviord System Boot/Shutdown in UTMP... [ OK ] Finished systemd-update-utmp.serviecord System Boot/Shutdown in UTMP. [ OK ] Started systemd-resolved.service - Network Name Resolution. [ OK ] Reached target nss-lookup.target - Host and Network Name Lookups. [ OK ] Reached target sysinit.target - System Initialization. [ OK ] Started amasone-netplan-watcher.path. [ OK ] Started amasone-time-watcher.path. [ OK ] Started swupdate-deb-srv-watcher.path. [ OK ] Started swupdate-os-srv-watcher.path. [ OK ] Started swupdate-reset-srv-watcher.path. [ OK ] Started systemd-tmpfiles-clean.timy Cleanup of Temporary Directories. [ OK ] Reached target paths.target - Path Units. [ OK ] Listening on avahi-daemon.socket -DNS/DNS-SD Stack Activation Socket. [ OK ] Listening on dbus.socket - D-Bus System Message Bus Socket. [ OK ] Listening on sshd-unix-local.socketemd-ssh-generator, AF_UNIX Local). [ OK ] Listening on systemd-hostnamed.socket - Hostname Service Socket. [ OK ] Reached target sockets.target - Socket Units. Starting armbian-hardware-monitor.ce - Armbian hardware monitoring... Starting armbian-hardware-optimize - Armbian hardware optimization... [ OK ] Finished armbian-hardware-monitor.vice - Armbian hardware monitoring. [ OK ] Finished armbian-hardware-optimizece - Armbian hardware optimization. [ OK ] Reached target basic.target - Basic System. Starting alsa-restore.service - Save/Restore Sound Card State... Starting amasone-netplan-watcher.smasone netplan service restarter... Starting amasone-time-watcher.serv- amasone time service restarter... Starting avahi-daemon.service - Avahi mDNS/DNS-SD Stack... [ OK ] Started cron.service - Regular background program processing daemon. Starting dbus.service - D-Bus System Message Bus... Starting e2scrub_reap.service - Rene ext4 Metadata Check Snapshots... Starting rsyslog.service - System Logging Service... Starting systemd-logind.service - User Login Management... [ OK ] Finished alsa-restore.service - Save/Restore Sound Card State. [ OK ] Reached target sound.target - Sound Card. [ OK ] Started amasone-netplan.service - Sone netplan configuration service. [ OK ] Started amasone-time.service - amaAmaSone time configuration service. [ OK ] Started dbus.service - D-Bus System Message Bus. [ OK ] Finished e2scrub_reap.service - Reline ext4 Metadata Check Snapshots. [ 35.582486] systemd-journald[309]: Received client request to relinquish /var/log/journal/4d855ca580a84d31b87ed4979a2cc49b access. [ OK ] Started systemd-logind.service - User Login Management. [ OK ] Finished amasone-netplan-watcher.s amasone netplan service restarter. [ OK ] Finished amasone-time-watcher.serve - amasone time service restarter. Starting NetworkManager.service - Network Manager... Starting wpa_supplicant.service - WPA supplicant... [ OK ] Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack. [ OK ] Started wpa_supplicant.service - WPA supplicant. [ OK ] Started rsyslog.service - System Logging Service. [*** ] Job NetworkManager.service/start running (29s / 10min 24s) [ *** ] Job NetworkManager.service/start running (29s / 10min 24s) [ *** ] Job NetworkManager.service/start running (30s / 10min 24s) [ ***] Job NetworkManager.service/start running (30s / 10min 24s) [ **] Job NetworkManager.service/start running (31s / 10min 24s) [ *] Job NetworkManager.service/start running (31s / 10min 24s) [ **] Job NetworkManager.service/start running (32s / 10min 24s) Starting systemd-hostnamed.service - Hostname Service... [ ***] (2 of 2) Job systemd-hostnamed.serve/start running (288ms / 1min 30s) [ OK ] Started systemd-hostnamed.service - Hostname Service. [ *** ] Job NetworkManager.service/start running (35s / 10min 24s) [ *** ] Job NetworkManager.service/start running (35s / 10min 24s) Starting NetworkManager-dispatcheranager Script Dispatcher Service... [*** ] (1 of 2) Job NetworkManager.service/start running (36s / 10min 24s) [ OK ] Started NetworkManager-dispatcher. Manager Script Dispatcher Service. [ OK ] Started NetworkManager.service - Network Manager. [ OK ] Reached target network.target - Network. Starting chrony.service - chrony, an NTP client/server... Starting openvpn.service - OpenVPN service... Starting rc-local.service - /etc/rc.local Compatibility... Starting ssh.service - OpenBSD Secure Shell server... Starting swupdate-deb-srv-watcher.ice - swupdate DEB srv restarter... Starting swupdate-os-srv-watcher.svice - swupdate OS srv restarter... Starting swupdate-reset-srv-watchee - swupdate reset srv restarter... Starting systemd-user-sessions.service - Permit User Sessions... [ OK ] Finished openvpn.service - OpenVPN service. [ OK ] Started rc-local.service - /etc/rc.local Compatibility. [ OK ] Finished systemd-user-sessions.service - Permit User Sessions. [ OK ] Started getty@tty1.service - Getty on tty1. [ OK ] Started serial-getty@ttyS2.service - Serial Getty on ttyS2. [ OK ] Reached target getty.target - Login Prompts. [ OK ] Started swupdate-deb-srv.service -one SW update of DEB files service. [ OK ] Started swupdate-os-srv.service - 1: AmaSone SW update of OS service. [ OK ] Started swupdate-reset-srv.service1: AmaSone SW update reset service. [ OK ] Finished swupdate-deb-srv-watcher.rvice - swupdate DEB srv restarter. [ OK ] Finished swupdate-os-srv-watcher.service - swupdate OS srv restarter. [ OK ] Finished swupdate-reset-srv-watcheice - swupdate reset srv restarter. [ OK ] Started chrony.service - chrony, an NTP client/server. [ OK ] Reached target time-sync.target - System Time Synchronized. [ 51.101789] irq 26: nobody cared (try booting with the "irqpoll" option) [ 51.108524] CPU: 0 PID: 55 Comm: irq/26-tps65219 Not tainted 6.6.54-edge-k3 #2 [ 51.115746] Hardware name: Texas Instruments AM625 SK (DT) [ 51.121223] Call trace: [ 51.123662] dump_backtrace+0x90/0xe8 [ 51.127339] show_stack+0x18/0x24 [ 51.130651] dump_stack_lvl+0x48/0x60 [ 51.134314] dump_stack+0x18/0x24 [ 51.137625] __report_bad_irq+0x38/0xe0 [ 51.141461] note_interrupt+0x330/0x390 [ 51.145292] handle_irq_event+0x9c/0xac [ 51.149122] handle_fasteoi_irq+0xa4/0x238 [ 51.153214] generic_handle_domain_irq+0x2c/0x44 [ 51.157824] gic_handle_irq+0x50/0x128 [ 51.161565] call_on_irq_stack+0x24/0x4c [ 51.165480] do_interrupt_handler+0x80/0x84 [ 51.169657] el1_interrupt+0x34/0x68 [ 51.173231] el1h_64_irq_handler+0x18/0x24 [ 51.177319] el1h_64_irq+0x64/0x68 [ 51.180713] _raw_spin_unlock_irq+0x10/0x44 [ 51.184893] irq_thread_fn+0x60/0xa8 [ 51.188463] irq_thread+0x168/0x24c [ 51.191945] kthread+0x118/0x11c [ 51.195172] ret_from_fork+0x10/0x20 [ 51.198742] handlers: [ 51.201005] [<00000000bec6e310>] irq_default_primary_handler threaded [<00000000300291f8>] regmap_irq_thread [ 51.210841] Disabling IRQ #26 [ OK ] Started dpkg-db-backup.timer - Daily dpkg database backup timer. [ OK ] Started e2scrub_all.timer - PeriodMetadata Check for All Filesystems. [ OK ] Started fake-hwclock-save.timer - Periodically save current clock. [ OK ] Started fstrim.timer - Discard unused filesystem blocks once a week. [ OK ] Started logrotate.timer - Daily rotation of log files. [ OK ] Started man-db.timer - Daily man-db regeneration. [ OK ] Reached target timers.target - Timer Units. Starting armbian-led-state.service - Armbian leds state... [ OK ] Started ssh.service - OpenBSD Secure Shell server. [ OK ] Reached target multi-user.target - Multi-User System. [ OK ] Reached target graphical.target - Graphical Interface. Starting systemd-update-utmp-runle- Record Runlevel Change in UTMP... [ OK ] Finished armbian-led-state.service - Armbian leds state. [ OK ] Finished systemd-update-utmp-runlee - Record Runlevel Change in UTMP. AmaSone 24.11.0-trunk Sid ttyS2 amasone-visitor login: root Password: _ ___ /_\ _ __ __ _/ __| ___ _ _ ___ / _ \| ' \/ _` \__ \/ _ \ ' \/ -_) /_/ \_\_|_|_\__,_|___/\___/_||_\___| v24.11 rolling for AmaSone Visitor running Armbian Linux 6.6.54-edge-k3 Packages: Debian rolling (trixie) Support: DIY (custom image) IP addresses: (LAN) 192.168.1.160 (WAN) 50.39.185.35 Performance: Load: 152% Up time: 1 min Memory usage: 11% of 883M CPU temp: 42 C Usage of /: 36% of 5.7G Commands: System monitor : htop Installer : armbian-install root@amasone-visitor:~#
Hi Anthony,
I think I have isolated the issue. The pin control node naming is what's incorrect. I would recommend running make CHECK_DTBS=y on your dtb file, if you have not already. I don't have your exact set-up, so let me know if this solution works.
Reference DTSchema for Pin Control: https://www.kernel.org/doc/Documentation/devicetree/bindings/pinctrl/pinctrl-single.yaml
Issue: in the original thread, the pmic pinctrl naming was incorrect.
main_gpio1_pmic_intr_pins_default: main-gpio1-pmic-intr-pins-default
Solution: ensure your naming ends with -pins
pmic_irq_pins_default: pmic-irq-default-pins
So the correct solution from the original thread would be:
main_gpio1_pmic_intr_pins_default: main-gpio1-pmic-intr-default-pins
Thank you for your patience & let me know if this solves your issue!
sorry, but this had no effect. Changed all "pins-default" to "default-pins" in device tree, and it had absolutely no effect on the unclaimed IRQ.
Hi Anthony,
Can you send your dts file? Can you confirm that you have an external pull up resistor for the PMIC output INT pin? If you do not, add one & see if the IRQ issue is resolved. This was the solution to someone who had a similar boot log, but with IRQ 27 instead of 26.
