The DCDC module uses UCC28C45 with an output voltage of 12V. If the voltage exceeds 12V, the driver will shut down. There is no problem using the old chip and it works normally. The chip recently purchased by the customer has an output voltage exceeding 15V, and the driver cannot be turned off, causing the circuit board to burn out. The schematic diagram is shown below. Please help analyze the cause.
