Part Number: LM5171
Dear Support,
The LM5171 datasheet shows the voltage loop compensation in Fig. 8-5, as shown below. This this correctly shows the voltage feedback divider Rlfbt and Rlfbb which represent the voltage feedback attenuation factor H.
However, the voltage loop block diagram, Fig. 8-4 does not show the voltage attenuation factor H, which implies that H=1, unity feedback which is not the case.
Also, equation (66), total open loop gain of the outer voltage loop, does not contain the voltage attenuation factor H.
The LM5171 converter design tool spreadsheet however does require the value of H to calculate the buck mode voltage loop compensation.
Please could you explain or justify the omission of H from the block diagram (Fig8-4) and the total open loop gain equation (66). Clearly the design equations provided will not result in the correct compensation component values if H is not taken into account.
Rob
