TPS65224-Q1: Non-volatile memory programming and tool?
Part Number: TPS65224-Q1
Other Parts Discussed in Thread: TPS65224
We are planning to use TPS62875 and TPS65224 in the design which needs to start at specific voltage settings.
The datasheet says that the default settings are taken from non-volatile memory, so I am assuming that it has to be programmed.
Is there a detailed description of the programming algorithm that we can implement? Is there a specific tool/spreadsheet to generate programming information?
If we build such programmer, what is the interface to the PMIC to program non-volatile memory - I2C? Any additional signals or voltages involved in programming?
What is the state of the device when it comes from the factory?
    this device can't be programmed by customer. If you want to discuss more please work with your local sales team to submit your question to the internal forums where I can answer in more detail.
    regards,
    Niko
