Other Parts Discussed in Thread: HSS-2HCS10EVM
Hi Team,
i have questions related to implementation of CRC on TPS2HCS
1) For CRC Enable Data Transmission is 24 -Bit, Correct?
2) after the CRC is enable. Does Frame is 28-Bit or 32-Bit?
Frame Format is CRC ADDRESS DATA Correct? It would be nice to add CRC Enabled SPI Frame Format to Data Sheet.
3)Was using the CRC calculation provided in the https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1412989/faq-tps2hcs10-q1-crc-calculation-function-example?tisearch=e2e-sitesearch&keymatch=CRC-4#
Do you have reference sheet to compare with it? was not getting anything from the Device after the CRC enabled.
