Part Number: UCC28951-Q1
1. The delay resistor values calculated in excel sheet vary based on shim inductor value and transformer leakage inductance value. Which row is correct and where to fill data ?
2. In application notes , we have seen ( 2* Coss ) is calculated for tank frequency. Does excel also considers the same ? Or should we manually do ( 2* Coss )
3. Why 2* Coss should be considered if that's correct.
4. If shim inductor value is mounted more than desired , what can happen? And what we need to take care.
