Part Number: BQ25170
Hi team,
In related thread, below are described.
- The charge disable function of the TS pin provides a means to turn off automatic recharge, which is part of the charging profile by default.
- System will need to have a method to reenable charging when desired as device does not monitor battery voltage when disabled via the TS pin.
Does this mean that once the IC has been disabled via the TS pin, charging will not start simply by plugging the input source?
Best regads,
Goto
